Old 07-09-2013, 12:25 PM   #141
QCCowboy's Avatar
Tip for you when running them. I ran the wiring down the right awning arm (closest to the camper nose) and through the hole for the electric awning. From there I ran it into the basement wall and tapped into the 12v dc outlet on the basement wall. Simple to do.
Jack of all trades - Master of none
2012 F350 CC DRW - 6.7L PSD
2014 Sabre 36QBOK
QCCowboy is offline   Reply With Quote
Old 07-09-2013, 01:09 PM   #142
Fulltime family RVer
Awesome! Thanks, Kevin. Makes it sound easier than I'm thinking it's going to be.
ependydad is online now   Reply With Quote
Old 07-09-2013, 02:42 PM   #143
QCCowboy's Avatar
No problem. I took a few pics throughout the process, including which wires I cut and soldered. Let me know if you want to see them. Probably the only ones I don't have are when I wired it to the 12v connection.
2014 Sabre 36QBOK
Old 07-11-2013, 02:32 PM   #144
Are the lights that y'all are buying labeled as waterproof
Brandon327 is offline   Reply With Quote
Old 07-11-2013, 02:58 PM   #145
Yes.
Old 07-11-2013, 09:43 PM   #146
Are y'all getting the 3528 s or the 5059 s
Old 07-11-2013, 09:48 PM   #147
5050s
Old 07-11-2013, 10:47 PM   #148
Yeah that was what I thought. I messed up and ordered the 3528 s I didn't realize till after the fact that there are different ones. Looks like now I will order some 5050s and return the others.
Old 07-11-2013, 10:57 PM   #149
It's just a brightness level, I believe. The 3528s may be sufficient.
Old 07-11-2013, 10:59 PM   #150
The 3528 s do not have a white light and they are not as bright.
