Old 03-14-2013, 10:52 PM   #11
its a single arm mount, no lock on it I figured foam rubber on each edge & foam blocks for travel under the bottom of tv, im not on the move as much as you.
2013 36qbok-7
2005 chevy lt 6.6 cc,drw
upgraded from a 94 holiday rambler 36brk
bcurvey is offline   Reply With Quote
Old 03-15-2013, 07:17 AM   #12
cabinet mods
adding some shelves to my cabinets
2013 36qbok-7
Old 03-15-2013, 07:19 AM   #13
the one the angle is the only way to get main cabinet shelf in they don't have opening big enough to angle it & fit
2013 36qbok-7
Old 03-17-2013, 09:08 PM   #14
LaydBack's Avatar
Speaking of grab bars, I want to mount a slim handrail of sorts for going down the inside steps. With a baby, those things feel really steep at 4am in the pitch black!
Nicely done all around! I'm going to copy your idea for the bathroom lock. I know my MIL would greatly appreciate it!
Thanks. I figured the bathroom that will probably see the most traffic should definitely be able to be secured. It's a bit tricky without a 3rd hand to steady the door, but as simple as it looks. If you look in the pic I've attached of the stairs, on the left you will see a grab bar that's factory. I guess FR listened to someone on that idea.
Name:	2013-03-03 21.02.35.jpg
LINK TO MY MODS
2012 F350 King Ranch DRW 6.7L
2013 Sabre 36QBOK-7 Platinum Package
LaydBack is offline   Reply With Quote
Old 03-18-2013, 07:26 AM   #15
Firefighter969's Avatar
Like the mods looks good
2000 F250 Superduty CC LB 7.3 4x4
2013 344QB Wildcat
Nights camped 2014 ( 15)
Nights Camped 2015 ( 4 )
Firefighter969 is offline   Reply With Quote
Old 03-19-2013, 08:57 AM   #16
Thanks for all the great ideas! I too have used a variation of your 1/2 bath lock. I used a bunk latch and put 2 hole for it to go into, one to lock it closed and one to lock it open. I then took the plastic snap that used to hold it open for travel and moved it so we can snap it to hold the door shut from the BH to keep the one year old from exploring and getting into trouble there!!
I added the BH tv on a swing arm. Its a 26 in with built in DVD.
Swapped out all the handles for locking ones. ( Don't understand why you could not even lock the bathroom door?!)
Added a level just inside the compartment because I have the pin cover and could not mount it there and I did not want to put any holes in the siding!
Another thing that was bothering me was the door to the BH. Why have it open to the dinette when you have a blank wall on the other side, so I flipped the door to swing the other way. Now we can leave it open and still get into the dinette.
Name:	Half Bath door locked open.jpg
ID:	25921   Click image for larger version
Name:	Half Bath door locked closed.jpg
ID:	25922   Click image for larger version
Name:	Half Bath doorplatic catch.jpg
ID:	25923   Click image for larger version
ID:	25924   Click image for larger version
Name:	BH TV Swung out.jpg
bluflame11 is offline   Reply With Quote
Old 03-19-2013, 11:10 AM   #17
QCCowboy's Avatar
Thanks for the ideas and pictures. I like the look of the bunk latches for the locks and what you have done with the door (having it open the other direction.) You all are giving me some great ideas on what to do, unfortunately my wallet isn't liking them quite as much Hopefully will be getting mine in the next couple of weeks so I can start contributing some pics and ideas here as well!
Jack of all trades - Master of none
2012 F350 CC DRW - 6.7L PSD
2014 Sabre 36QBOK
QCCowboy is offline   Reply With Quote
Old 03-19-2013, 10:51 PM   #18
36QBOK-7 Club
bigblue08's Avatar
Send a message via AIM to bigblue08 Send a message via MSN to bigblue08 Send a message via Skype™ to bigblue08
Did you get the bunk latches at Home Depot or something?
--Jay
2008 Chevy 3500 LTZ DRW
2013 Sabre 36QBOK-7
B&W Turn over ball and companion
Days Camped 2012 - 76
Days Camped 2013 - 7
bigblue08 is offline   Reply With Quote
Old 03-20-2013, 08:13 AM   #19
ordered them online, wanted to find the nickel ones, but could only find brass...I figure if I come across nickel ones, its only a few screws and a few dollars to swap out!
Old 03-20-2013, 08:33 AM   #20
36QBOK-7 Club
bigblue08's Avatar
I wonder if its possible to order them through forest river
--Jay
2013 Sabre 36QBOK-7
