Old 07-03-2014, 09:42 PM   #221
QCCowboy's Avatar
Originally Posted by MillerTime View Post
Sweet!!
Looks good!! That will be awesome, a vent you can actually use now
Thanks! Works great. I did have to cut the plastic trim piece down a bit to account for the slope in the roof, but a pretty easy install. Going to let the Dicor cure for a day before I reinstall the vent cover.
Jack of all trades - Master of none
2012 F350 CC DRW - 6.7L PSD
2014 Sabre 36QBOK
QCCowboy is offline   Reply With Quote
Old 07-05-2014, 09:52 AM   #222
tlambert's Avatar
What type of sealant is that you used on the roof to seal it and where can I get it?
Tim
tlambert is offline   Reply With Quote
Old 07-05-2014, 11:16 AM   #223
Oklahoma Proud
MillerTime's Avatar
Its gonna be self leveling Dicor.
You can get at almost any rv dealer or online.
I just resealed the attic vent I took apart last weekend checking for my OK vent. Dicor is supper easy to use and flows out to look beautiful. (I had to get white since nobody had almond or tan locally)
ID:	57203   Click image for larger version
Old 07-05-2014, 12:20 PM   #224
QCCowboy's Avatar
Yep. Exactly what I used. MillerTime, I got mine via the service department, the parts department didn't stock it at my dealer.
2014 Sabre 36QBOK
Old 07-05-2014, 08:49 PM   #225
tlambert's Avatar
Nice! Thanks. I will look for it.
Tim
Old 07-06-2014, 06:50 PM   #226
QCCowboy's Avatar
Put the Maxair II cover back on the new vent today. It still gave plenty of clearance to open it back up and give a lot of air flow.
2014 Sabre 36QBOK
Old 07-16-2014, 09:47 PM   #227
QCCowboy's Avatar
So we've had some great smelling water for the last couple trips, finally figured it out today that it was from a few trips ago in and the smell was coming from water still trapped in the filter. Rather than continue to pay $30 a filter for the KW1 filters I bought a standard filter canister that accepts standard 10" whole house filters and swapped them today. Pretty easy mod and now can get 2 filters for under $10 and can purchase them darn near anywhere! Took me a whopping 10 min to do.
2014 Sabre 36QBOK
Old 07-17-2014, 11:07 AM   #228
ctyankee's Avatar
Is anyone else as frustrated as we are with the cabinet doors in the BH? The closest ones to the bunks can barely open because of the slide out frame. Any suggestions?? I am considering taking the doors on both sides off, adding shelves and getting mesh nets to make sure everything stays in place. Thoughts???
Also posted in "Are there any 36QBOK out there?"
2014 Palomino Sabre 36QBOK
2008 Ford F-350 4x4 Crew diesel
ctyankee is offline   Reply With Quote
Old 07-17-2014, 01:51 PM   #229
QCCowboy's Avatar
Ours open, but I did add chains to them to prevent them from getting damaged by the corner brackets (someone pulling
them to hard.) We put stuff that is not frequently used in those sides.
2014 Sabre 36QBOK
Old 08-16-2014, 01:27 PM   #230
QCCowboy's Avatar
Got my new level installed. Much easier being able to tell side to side level of site without even leaving the truck!
2014 Sabre 36QBOK
