Old 08-23-2015, 06:22 AM   #271
LaydBack's Avatar
Mine typically holds temperature fairly well. The damage happened because it was at the dealer before the last trip, and they were supposed to keep it plugged in, and apparently their breaker tripped or it got unplugged, and I wasn't aware before hitting the road for 4+ hours. Here's the sticker on the back of my refrigerator. I've flirted with doing an inverter.... just haven't decided to dive into it.
LINK TO MY MODS
2012 F350 King Ranch DRW 6.7L
2013 Sabre 36QBOK-7 Platinum Package
LaydBack is offline   Reply With Quote
Old 08-23-2015, 06:35 AM   #272
Oklahoma Proud
MillerTime's Avatar
Looks good Steve!
Old 10-26-2015, 11:10 AM   #273
Originally Posted by QCCowboy View Post
Thought I would post another one here. The slam latches are pretty easy to bypass, and while I'm not as worried about protecting what is in there, I did have a problem where I could darn near open a basement door because of the gap between the door and the latch catch. Simple solution, put an o-ring underneath (both seals and rises the catch). Problem solved. Not sure if anyone else will have this issue, but it cost me somewhere in the neighborhood of $.50/latch).
I know this is a really old post but I had this same problem with one of my basement doors being able to be pulled open even when locked. I tried the o-ring fix and it didn't help.
What I finally did was take a square latch plate from a regular door, drilled some holes in it so I could line it up with the existing screws, and put it right on top the existing latch catches. It works perfect.
I didn't take any pics, but the latch plate looks something like this:
The one I used was a little longer and had more room past the existing holes.
Iwritecode is online now   Reply With Quote
Old 11-23-2016, 07:42 PM   #274
Oklahoma Proud
MillerTime's Avatar
Dang, its been over a year since anyone posted in here. Just went and winterized our sabre last weekend. I plan on using it some this winter and i wanted to speed up the winterization process for the future. (I forgot to take pics of my mod though)
Anyways, i cut a square flap in my cloriplast just in front of the wheels on the door side and found the water lines.
I then installed 1/4 turn ball valve shark bites on the lines just rearward of the kitchen sink t's.
This way after i winterized, i just shut the valves and now we can use the front water lines and winterize just them.
I believe last summer i deleted the house water filter since we just use the blue torpedo filter anyways. This also helps speed up my winterization!
Heres test hitching the camper to make sure the hitch is setup right for this truck. Probably taking it to a buddy place in a couple weeks.
Old 11-23-2016, 07:47 PM   #275
Oklahoma Proud
MillerTime's Avatar
Oh and Steve, if you still look on here.....
Im going to have to do an outside kitchen counter top mod too. My counter is swelling right in front of the sink a little and behind it was delaminating slightly when i was defrosting the fridge and it leaked out some water.
I think i will use fiberglass and gelcoat and just make a counter top, but i might order some carbon fiber and really trick it out!
Old 11-23-2016, 07:56 PM   #276
Fulltime family RVer
If you make one, know that I may be through Oklahoma in the spring.
Old 11-23-2016, 08:05 PM   #277
Ok, so mods to my 36QBOK.
I replaced a wood panel in the bunkhouse with a metal mesh. There are water lines to the outdoor kitchen that have leaked. The cold and hot happened back to back in cool-cold weather last January. I'm hopeful that this let's warm air from the room to them and keeps them from freezing.
Old 11-23-2016, 08:08 PM   #278
We replaced the glass in the cabinet doors above the TV. We are Disney freaks and have quite a pin collection. It used to reside on a pin board that we sit on the top of the big slide in that room. But it was something we had to move every time we moved.
We plan on replacing the glass out of the doors above the couch. We won't do pin boards, but we'll take similar metal and paint it.
Old 11-23-2016, 08:11 PM   #279
Added support/lift arms and a hinge to the bed in order to get access to a little more storage for off-season clothes.
I'm pretty happy with how this turned out.
Old 11-23-2016, 08:14 PM   #280
Added a 1/2" layer of plywood to the lower bunk so that it didn't creak and scare me so much. I was afraid that we were going to put a foot thru the thin luan that was there before.
We are thinking of painting some roads for my son's Hot Wheels on it. Not sure yet.
