Old 03-30-2013, 09:36 PM   #31
QCCowboy's Avatar
Here are the pics for the rest of the roof mods that I did if anyone is interested. Thought I would take photos of every step of the installation of the MaxAir II vents in case someone wanted to know how to install them. There is also a pic of the Winegard Wingman as well (just no install pics, but it is extremely simple.)
Roof Mods Photos by qccowboy | Photobucket
Jack of all trades - Master of none
2012 F350 CC DRW - 6.7L PSD
2014 Sabre 36QBOK
QCCowboy is offline   Reply With Quote
Old 03-30-2013, 10:13 PM   #32
speedcat's Avatar
Great idea with the double sided tape!! Gonna have to steal that idea. Looks good!!
2018 Heartland Landmark 365 Charleston
2008 Ford F350 King Ranch CC DRW 6.4l, 4.10 diff
B&W companion
Airlift system/on board compressor
speedcat is offline   Reply With Quote
Old 03-30-2013, 10:33 PM   #33
LaydBack's Avatar
I got a few mods done today too. I put MaxxAir Fanmate covers on both bath fans, wired the furnace blower to a rocker switch to allow me to run just the blower without the furnace igniting, and extended the gas line to the rear and added 2 more propane quick connects. I also managed to get a lot of moving in done. I'll have to post pics later.
LINK TO MY MODS
2012 F350 King Ranch DRW 6.7L
2013 Sabre 36QBOK-7 Platinum Package
LaydBack is offline   Reply With Quote
Old 03-30-2013, 10:51 PM   #34
QCCowboy's Avatar
Just out of curiosity, why change the location of the quick connect and add more?
2014 Sabre 36QBOK
Old 03-30-2013, 11:30 PM   #35
mhuffs9017's Avatar
Thanks QCCowboy for the great pics! Can you please detail your tv mount details for both master and bunkhouse? Item numbers, search Amazon for? etc.... Thanks in advance!
2013 F350 DRW 6.7 3.73 - Lariat Ultimate FX4 - Tuxedo Black - 14K GVWR
2013 Sabre 36QBOK
2012 Rinker 246BR - "Off The Grid"
Nights Camped 2013 - Not enough!
mhuffs9017 is offline   Reply With Quote
Old 03-30-2013, 11:30 PM   #36
mhuffs9017's Avatar
Has anyone tackled, or have any ideas what they are going to do about the TV in storage area?
2013 Sabre 36QBOK
Old 03-30-2013, 11:38 PM   #37
QCCowboy's Avatar
Got the one for the master at WM. Used it in my last 5vr and it worked great. When I traded it I removed the mount to use with the new one.
Here is the link:
Small Tilting TV Mount for 13" - 26" TVs: TV & Video : Walmart.com
For the one in the bunkhouse, I did order from Amazon. I read a lot of reviews and wound up with this one.
Amazon.com: Cheetah Mounts ALAMB Articulating Arm TV Wall Mount Bracket for VESA 100 12-24" LCD LED Flat Screen Monitors Display/TVs up to 40lbs Includes Free 10' HDMI Cable and 6" Bubble Level: Electronics
2014 Sabre 36QBOK
Old 03-31-2013, 08:59 AM   #38
LaydBack's Avatar
I didn't change the location, I added more pipe from that location and extended it to the rear of the outside kitchen slide. This will allow me to use the stove and a grill at the same time. I also added the 3rd one in case we have dinner in the smoker and want to use the other things to prepare lunch.
ID:	26775   Click image for larger version
LINK TO MY MODS
Old 03-31-2013, 09:04 AM   #39
QCCowboy's Avatar
Very nice. I like the idea. Been running my WeberQ off of the 1lb. tanks. Been contemplating pulling the regulator off and running through RV system. If I do this will be a mod I have to consider.
2014 Sabre 36QBOK
Old 03-31-2013, 09:25 AM   #40
LaydBack's Avatar
I think that's next on my list......I have the idea and some of the parts, just finalizing my approach. The height of my 32" TV is going to not allow it to be as simple as I originally imagined. Here's the pics of the rest of what I did yesterday.
The furnace blower mod is actually really simple. In my last unit, we used it with electric heaters and also when running the AC. It seemed to keep the temperature more even throughout the camper. You start by turning off the propane, and since I was going to be adding to the gas piping, I also disconnected both tanks. I then removed the furnace fuse at the distribution panel. Once you remove the outside access cover, there's 1 screw centered vertically on the left, that you remove and disconnect the gas line. The furnace should then be able to pull out. I only needed to pull it out as far as the pics show. There's 2 screws (they're already removed in my pics) holding the metal bracket that the circuit board is on, that you remove, and then you can pull the board and bracket out. You have to remove the harness I'm pointing to in the pic, to be able to get the board out where you can work on it. Then it's just a matter of wiring in the 2 conductor cable to your switch. I routed mine thru the basement to where the subwoofer is. I mouted the switch on the subwoofer grille, but I left enough cable to eventually put it over where all the other controls are, just inside the door. I used an illuminated switch so that I can see it through the grill, and just tapped the (-) for the switch off of the propane/CO detector. You have to be careful to not knick any wires when sliding the furnace in/out but it's easy enough to avoid doing so.
ID:	26777   Click image for larger version
ID:	26778   Click image for larger version
ID:	26779   Click image for larger version
ID:	26780   Click image for larger version
LINK TO MY MODS
