Old 03-31-2013, 10:23 AM   #41
LaydBack's Avatar
Originally Posted by QCCowboy View Post
Very nice. I like the idea. Been running my WeberQ off of the 1lb. tanks. Been contemplating pulling the regulator off and running through RV system. If I do this will be a mod I have to consider.
This was a very easy mod as well. I shut down and disconnected the propane tanks. I took the 90 elbow and quick connect off and put a T on. Home Depot sells black iron pipe in precut and threaded lengths, and the 6' length worked perfectly. I put the 90 elbow at the end of the 6' length and used a 1 1/2" nipple to another T, turned sideways. From there, I just used the proper brass fittings to adapt the quick connects. I too have a Weber Q200 that I've outfitted for the camper. Complete with thermometer, grill light, and quick connect. The grill light is really nice, and you can set it to go on/off with the opening/closing of the lid.
ID:	26789   Click image for larger version
ID:	26790   Click image for larger version
LINK TO MY MODS
2012 F350 King Ranch DRW 6.7L
2013 Sabre 36QBOK-7 Platinum Package
LaydBack is offline   Reply With Quote
Old 04-02-2013, 10:48 PM   #42
LaydBack's Avatar
Slide Out Basement TV Prototype
Made the slide out for the basement TV this evening. I would have loved to use a heavy plastic or aluminum, but have yet to find a rea$onable source, so I'm thinking I'll just spray all the wood with bedliner spray. I already plan to make a couple of revisions, one being to use a bigger piece of wood to make the 2 pieces that form the backwards "L" be 1 piece. That'll shave off a little overall thickness of the setup. The other revision is that I originally used a small piece of wood for the mount. I noticed the slides wanting to twist, so I added another piece of wood. I will revise it to make that 1 longer piece of wood.
I used this mount Wall Mount World | RV and Marine | Articulating Tilting, which I lucked up and scored from a member on another forum for $50 shipped. The way I have it designed, I'll have to remove the TV from the mount base plate for travel, and remount the TV to the mount base when setting up. I will be able to slide the setup in and articulate the TV into the baggage door opening at the end of the evening, so at least I don't have to tear it down constantly. Also, I used some slides that came off of a trash can cabinet that was getting demo'd on the job I'm on. I would say try to get the heaviest duty ones you can find and nothing under 22" full extension.
I typed this once with more detail, and my laptop shutdown before I could post it. I'll update again after more progress....hopefully I can make the revisions tomorrow and get it set in the camper. Anyone planning to do this, I'd say the most attention needs to be paid to figuring out the proper height that the mount and slides need to be installed at. For me, the trick was getting it set at a height where it could stow just inside the baggage door without having to unmount it. That takes a bit of measuring to figure out how everything offsets.
Name:	2013-04-02 21.08.51.jpg
ID:	26979   Click image for larger version
Name:	2013-04-02 21.05.24.jpg
ID:	26980   Click image for larger version
Name:	2013-04-02 21.07.28.jpg
LINK TO MY MODS
Old 04-03-2013, 06:35 PM   #43
Added a 50 amp outlet outside and a progressive industries EMS system today
bluflame11 is offline   Reply With Quote
Old 04-03-2013, 06:38 PM   #44
QCCowboy's Avatar
Ummm.....50 amp outlet outside? Meaning outside of your house to plug your QBOK into?
You are going to love the PI unit. Where did you wind up mounting everything?
Jack of all trades - Master of none
2012 F350 CC DRW - 6.7L PSD
2014 Sabre 36QBOK
QCCowboy is offline   Reply With Quote
Old 04-03-2013, 06:41 PM   #45
Yep! On the side of the garage to plug the 5ER into...as for the pi, I mounted the unit behind the central vac and the remote just above the breaker panel.
It was a little tight to work in there, but not bad!
Old 04-03-2013, 06:44 PM   #46
QCCowboy's Avatar
Nice. Wish I could run a 50 amp for mine, but our entire house, including garage is finished....Running that one would be a real PITA.
2014 Sabre 36QBOK
Old 04-03-2013, 06:48 PM   #47
LaydBack's Avatar
Slide Out Basement TV Done
Just finished her up. Everything worked out as planned. Will be very simple and rea$onable mod to build. Minus the mount I'd say <$50. I'll edit this post or add another with more details.
ID:	27013   Click image for larger version
ID:	27014   Click image for larger version
LINK TO MY MODS
Old 04-03-2013, 06:57 PM   #48
QCCowboy's Avatar
Looks great!
2014 Sabre 36QBOK
Old 04-03-2013, 07:03 PM   #49
LaydBack's Avatar
Looks great!
Thanks. Tuning in the channels in the driveway.
LINK TO MY MODS
Old 04-03-2013, 08:26 PM   #50
Very nice!
