Old 09-20-2016, 09:38 AM   #1
Thermistor on Dometic DM2652
Has anyone used the Articca snip the tip repair kit to replace the existing thermistor ? This kit also gives you an adjustable thermostat. Hope it will help with better frig cooling. Have already blocked off upper outside air pockets around frig and on top. Also removed small existing fan and replaced with two larger ones. Hope all this will get me to keep frig temp close to 40d. Even the dealer says with the frig in a slide out 43 is about the best to expect. That is N G . What a poor design. Prior to all this, we would see temps up to 53 in the heat of the day. The freezer has been always good. Thank for your time.
Slyfox is offline   Reply With Quote
dometic
