07-19-2009, 06:11 PM
#41
need help..installed ritetemp 6022 on my durotherm..ac works as it supposed to, but in the heat mode ac fan runs as well??anyone got the solution??
wired:yellow to y, white to w, green to rh, brown to g, red and blue not connected.
07-19-2009, 06:35 PM
#42
The Jolly Mon
I'm not sure, but here is a link to the install instructions and their support phone number is there too. Loads of info...if you don't already have that. Maybe a call to them would better answer the WHY question. Mine didn't do that, however.
http://www.ritetemp-thermostats.com/6022.html
Pete (Jolly Mon)
2018 Wildwood Grand Lodge 42 DLTS
-Seasonal Space, Northern MN.
-2017 Sylvan 8522 LZ LES/115 Merc/Sea Legs
07-23-2009, 09:16 AM
#43
install/reinstall update
just some comments..finally got a digital thermostat installed and working..had to replace the ritetemp#6022 made in china crap with a honeywell#rth110b also made in china..ritetemp#6022 evidently has too too many "bells and whistles" to work properly w/ the durotherm/suburban system (11 terminals/7 jumpers)..instructions on jumpers sketchy..ritetemp tech support was NO support at all..will think long and hard before purchasing any ritetemp product again..while the honeywell stat is strictly "bare bones" basic it works the system..no clock, no programing, fewer terminals, jumpers, buttons..but both the cool and heat sides now work independantly of each other again..even got my money back on the ritetemp from home depot..all is once again COOL!!
07-24-2009, 06:32 PM
#45
The Jolly Mon
My RiteTemp is working great, and was very easy to install. I wonder why your model differed???
Pete (Jolly Mon)
10-18-2009, 10:00 PM
#46
2010 Sandpiper 345RET
Just curious NDJollyMon, do they still sell the 8085c? I can't find it.
10-18-2009, 10:13 PM
#47
The Jolly Mon
I believe that model has been replaced with a new one. You can check the Rite Temp site matrix and find one that will work in RV's. Not sure what models, but their Customer Service will know.
My Rite Temp is still working great. Nice upgrade!
Pete (Jolly Mon)
01-03-2010, 05:56 PM
#48
jereld,
I installed the same T-stat over a year ago and had the same problem. Called Ritemp Tech. support, they were no help, they couldn't figure it out. I spent so much time with them on the phone the tech guy had to hang up. They are aloud only so much time per call weather they have fixed your problem or not. I did find that when I'm done with the A/C and want to run the furnace, I shut off the breaker to the A/C and when I turn the T-stat back to heat I turn the breaker back on. Works for me!
2001 Dodge Ram
2007 Palomino Thoroughbred F-829RKS
Kids all grown, 4 Grandkids to SPOIL
01-22-2010, 09:26 AM
#49
We swapped our analog/manual dometic thermostat out with a Hunter digital thermostat. It controls a dometic 13.5K A/C and a Suburban furnace. The details of the swap along with pictures can be seen at http://rvroadtrip.us/library/digital_thermostat.asp.
09-25-2010, 02:23 PM
#50
Can't get my Hunter 44668 to work
A little help with programmable thermostat wiring
So hopefully one of you, smarter than me in this electronics area, can help me with the connections for my programmable thermostat. I bought a Hunter Model 44660 from Lowes that's been discontinued. I realize that I am going to loose my two speed fan, but I think I can live with the lower speed setting.
Based on some information I got from another post I connected.
Red not used
Yellow to Y/C
White to W/B
Blue Not Used
Brown to G
Green to RC1
Jumper from RH - RC
But when the thermostat should call for heat both the heater fan and the air conditioner come on. And I can't feel any heat from the heater.
Here are photos of my connections
1st is the current Dometic Thermostat
2nd is the Booklet Diagrams for the New Thermostat
3rd is the connections post for the new thermostat.
2009 Ford 150 Platinum
2010 Rockwood 2604
09-25-2010, 02:27 PM
#51
Just at a quick glance I see that green on the old thermo is connected to the GND terminal, on your new one you connected it to RC1??? Shouldn't it be to the G terminal (I would suspect it is ground and is also on the far right side of both terminal blocks).
09-25-2010, 03:31 PM
#52
The Jolly Mon
Pete (Jolly Mon)
09-26-2010, 10:26 AM
#53
Okay, I got it working properly actually using the instruction provided 1st. I don't know what I had hooked up different from what was suggested but it worked when I went through and did it again. Unfortunately the Hunter XXX is a piece of crap; the latch that holds down the cover over the control panel is so flimsy that it broke the 1st time I closed it. I imagine that why it was on clearance. So I'll find another, hope the wiring goes a bit easier.
I liked the features of this one. It had a Daylight Savings mode and a Home today mode which I thought would be really helpful. But I imagine if I just replace it with the same model the latch on the new one is also likely to break.
2010 Rockwood 2604
11-03-2010, 11:51 AM
#54
Thermostat change out
House models are 24VAC NOT DC. Also programmable models require constant voltage to maintain the internal clock unless they are battery powered unit. Therefor you have VERY limited choices of thermostats that be used on your MH.
11-03-2010, 04:34 PM
#55
Nice Job! We, too changed the analog DuoTherm out and replaced it with a digital about half-way through the season - primarily in prep for a Fall camping trip, which, for a variety of reasons, we never got to make. I know it works, and now look forward to using same in the Spring!
Fire Instructor
2022 Coachmen Leprechaun 319MB
2022 Ford Ranger toad
09-07-2011, 07:02 PM
#56
Just curious on some relatively long-term feedback regarding battery life on the digital t-stat mod. I was under the impression that the batteries in these type of stats were merely to hold programming in the event of a power failure, or to allow "arm-chair" programming. With the relays in these stats now being powered by relatively low capacity batteries, are you finding reasonable battery life?
09-07-2011, 08:33 PM
#57
My t'stat takes one or two AAA's (I think). I put fresh batteries there, in my smoke detector, CO detector, television remotes, DVD player remote, all at the same time in the beginning of the season (April or May), then take them out when I winterize (late October). They last all season.
Fire Instructor
09-08-2011, 09:01 PM
#58
Very good plan, FI. Changing them ALL at the same time is a good idea, instead of replacing them all at random times when they go dead.
