Old 08-29-2014, 05:25 PM   #1
collinpr's Avatar
Timbrens Advice please
I did a search on here, but mostly comparisons between these and airbags.
I am not interested in Airbags, however i would like to know if anyone has installed the Timbrens on a 1 ton with duals. Tuck is a '14 Ram 3500 DRW, 8ft box 4X4. (I do not receive the trailer until mid Sept.)
Any improvement in ride when towing? Are they necessary? Did your rear sag without them?
My 5ver is 12000lbs dry weight, pin weight around 2000 lbs.
Thanks....
collinpr is offline   Reply With Quote
Old 08-29-2014, 06:05 PM   #2
Twisty's Avatar
The payload on that truck should be so high that I can't see any sense in adding anything to it.
FOR SALE 2014 BOSS 6.2L F350
2012 Surveyor SV264
NW Oregon
Twisty is offline   Reply With Quote
Old 08-29-2014, 06:05 PM   #3
We run the air lift version called air cells in 7 trucks with dump inserts. They are nice because there is no mechanical parts like the air bags. I doubt you will need anything for that truck, our 1 ton dually with 3300lb pin wt rode level and sweet. My personal work truck i have air bags with auto level, it sits and rides the same wether I am empty, have 4500lbs of lumber or have either trailer hooked up. Headlight aim is never an issue, the front end allignment isnt affected by the squat so tires last longer and handling is better
2007 Cardinal 362bhle 5er
2006 f350 Diesel CC LB 4x4 4.10 locker lariat
1966 Mustang coupe...under construction
2004 Explorer 4.6 awd (16 year old daughters car)
2009 Mazda 6 (wife's ride)
Bunkfamily is offline   Reply With Quote
Old 08-30-2014, 04:04 PM   #4
10x
I installed the tibrens on my f250 and they work great. They only come in play when there is a load
2014 XLR 27 HFS
2010 F250 4x4 Crewcab Turbo Diesel
10x is offline   Reply With Quote
Old 08-30-2014, 04:19 PM   #5
WFD
I cant imagine a 3500 DRW needing timbrens....no way that trlr with a 2000 pin weight(which seems low btw...2500 would seem more in line) should bottom out your suspension where timbrens would even come into play. even if your pinweight is underestimated by 500 lbs...that is still nothing for that trucks payload...i think you would be wasting time and money adding them.
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
WFD is offline   Reply With Quote
Old 08-30-2014, 05:23 PM   #6
Camper Less Camping
Cajun Po-Boy's Avatar
X2...save your $ and use for fuel
2013 Sabre 32RCTS-6 (sold)
Cajun Po-Boy is offline   Reply With Quote
Old 08-30-2014, 07:22 PM   #7
collinpr's Avatar
Thank-you all for the input. I have to agree, I think I will just leave well enough alone for the time being.
We are going to Arizona again for the winter,, so the run down there will tell me if I need any additions to the suspension.
We live in Canada, so needless to say, we get screwed, chewed and tattooed on prices (eg. local shop wants $750.00 for two airbags installed, no compressor, just manual set up !!)......So, if I find I need to boost the suspension, I will be dropping the bucks (at a much lower cost) in the US of A .
Again, thanks much for the input.
Old 09-02-2014, 06:42 AM   #8
10x
True but the suspension still compresses some. The Tibrens take the load off the suspension when the compression occurs. They are adjustable for them the come in to play with more or less compression with the shims.
2014 XLR 27 HFS
Old 09-02-2014, 09:26 AM   #9
WFD
The suspension on a 3500 truck probably wont compress enough with his tongue/pin weight for the Timbrens to even come in to play.
