Old 02-09-2014, 07:07 PM   #1
Edgycanuck's Avatar
Tire and rim size on a flagstaff 23LB
So we purchased a Flagstaff 23Lb a year or so ago used (ever so slightly) I want to replace the rims and tires for a little more ground clearance (I'm doing a good job of grinding the rear triangles off especially after a 4000km road trip last summer. We're going to the Yukon and Alaska next summer and I don't really trust the tires for those roads so I figured replace the tires and rims. Any idea what size the white steel rims are (trailer in storage 2hrs away) and what size I can go to? I know my neighbor with the same trailer in a rockwood got the upgraded rims and bigger tires.
Thanks a lot
Edgycanuck is offline   Reply With Quote
Old 02-10-2014, 11:45 AM   #2
Canadian Member
itat's Avatar
According to this website they are ST205/75R14.
Flagstaff Micro Lite 23LB Bunkhouse / Bunks Travel Trailer RV by Forest River
That's a very common tire size for your size of trailer but the only way to be certain is to make a trip to your storage lot and check the actual tires.
Post your question about changing the rim and tire size in the "Running Gear, Axles, Brakes, Tires & Frames" thread and you should get some helpful responses.
2011 Rockwood Signature Ultra Lite 8293SS, 12K Equal-i-zer
2016 Ford F-250 XLT SuperCrew, 6.2L, 4x4, 6'9" bed, 3.73
Fondly remembered:
2009 Ford F-150 XLT SuperCrew, 5.4L, 4x4, 5'6" bed (2012 - 2016)
itat is online now   Reply With Quote
Old 02-10-2014, 02:05 PM   #3
Edgycanuck's Avatar
Thanks for the effort. I had seen that add as well. But I found out the rv show that now for 2014 the standard size was 14" but they couldn't tell me about 2012. I'm hoping to bring it back home in the next month or so then I can confirm the size. But I will definitely post in the other section.
23lb, flagstaff, tire
