Old 09-16-2014, 01:52 PM   #1
RKR
RKR's Avatar
Tire Tracker TPMS & Metal Stems
Does anyone that uses this system have metal valve stems ? I remember reading where someone was having issues with their TPMS when they swapped over to the metal stems.
I'm thinking about swapping trailer tires and I would rather have metal stems but I want to make sure they won't interfere with my TPMS.
Sent from my high tech gadget
RKR is offline   Reply With Quote
Old 09-16-2014, 02:18 PM   #2
TURBS's Avatar
I have a tire traker with metal stems.
Haven't had any issues.
TURBS
How can I annoy OC today?
Old 09-16-2014, 02:24 PM   #3
offroad's Avatar
I believe several are using metal stems with their TPMS and some had to go to metal after the weight of the sensors was causing leakage in their rubber stems.
2017 Open Range - Light 297RLS, BX1 Gooseneck
2014 Ram 2500 4x4 CCSB 6.7L 68RFE
offroad is offline   Reply With Quote
Old 09-16-2014, 02:27 PM   #4
RKR
RKR's Avatar
Thanks guys.
Old 09-16-2014, 03:41 PM   #5
Tried the high pressure rubber stems with TST 507 Flow Thru and one started leaking so Ms. Amy and FT Turbs graciously sent me metal stems which I then had to trade for smaller steel ones that fit my wheels. Had the tires broken down and the steel stems installed and re-balanced with the sensors on them. Now, when we go to FL, I will re-torque the lugs a couple or 3 times the first day when we make potty stops, etc. I would suggest you balance the tires WITH the sensors as they will throw the balance off.
Old 09-16-2014, 04:40 PM   #6
RKR
RKR's Avatar
Will do OC. Thanks
Old 09-16-2014, 05:13 PM   #7
BombDoc's Avatar
No problems here. I purchased the TPMS in Goshen and drove back to SC. I have metal stems on my stock wheels. Made several shorter trips since Goshen and have had no issues.
John & April & "Scout"
2013 Sabre 32RCTS-6
Nights Camped 2013-(44) 2014-(59) 2015-(47)
2016-(32) 2017-(13) 2018-0
BombDoc is online now   Reply With Quote
Old 09-16-2014, 05:24 PM   #8
Witch Doctor's Avatar
I think you should have Goshen SURVIVOR not Veteran......
Coachmen M/H
Concord
2018 / 300 DSC
Old 09-16-2014, 05:28 PM   #9
BombDoc's Avatar
I think you might be right. After all the shenanigans that went on there, Survivor might be better than veteran.
2013 Sabre 32RCTS-6
Old 09-16-2014, 07:55 PM   #10
RKR
RKR's Avatar
I might have do that Goshen thing next year. I read about all the Phat Phrog shenanigans and I'm intrigued.
I did take a golf cart once and floored it down hill from the clubhouse to the driving range. Straight shot.I then proceeded to launch off the tee box and landed on the driving range. Caught some good air but I didn't roll it.
My drunk golfing buddies and I were asked not to come back. Found out those uppity Country Clubs don't have a sense of humor.
tire
