Old 05-04-2012, 05:36 AM   #1
4kmprs's Avatar
Tires and wheels?
My 2004 f150 lariat screw 3.73 has the factory 18 in tires and rims. its time to replace the tires and i would like to know if i should consider changing out the rims for 17's.
what are the pros and cons? will i see/feel a difference in mileage, ride, comfort, towing?
thx
Kevin, Meg and DDx2
2012 Rockwood Roo 233s
2004 F150 Super Crew 5.4L 3.73 4x4
Days Camped 2012 = 42
Days Camped 2013 = 9 planned before April 1st
Local Ohio CGs - Punderson SP and West Branch SP
4kmprs is offline   Reply With Quote
Old 05-04-2012, 06:04 AM   #2
jd-ford-hd's Avatar
If you do the swap, research tire specs to get the 17" that has the exact same outside diameter to retain speedometer accuracy. Also choose the 17 that has the exact same or greater individual weight carrying capacity. One pro is the 17 tires may cost a little less. The other pro is the smaller wheel diameter with the same tire outside diameter means there is a little more tire sidewall possibly giving a little softer ride. The cons. You have to buy wheels..! Another con. When trading or selling your truck, a nit picking buyer will open the door and see the original tire data sticker and say "What's up with this?"
"IF IT AINT GOT A MOTOR, I AINT INTERESTED"
jd-ford-hd is offline   Reply With Quote
Old 05-04-2012, 06:09 AM   #3
4kmprs's Avatar
Thanks DJ-ford.
Very helpful.
If I go this route I would keep the 18 in rims for resale
Kevin, Meg and DDx2
Old 05-04-2012, 06:09 AM   #4
dretired's Avatar
thx
My 2010 F150 came with Michelin ..18"..I like them ...i am pretty sure they are LTX ... "P" rated tire ..probably ..but i like the ride, traction,etc
2014 Crusader 325 TE....2012.. F 250.. Supercab XLT, 4x2 , diesel....days camped 2011 ... 28.... days camped 2012...115 ... days camped 2013...155...2014...171 and counting
dretired is offline   Reply With Quote
Old 05-04-2012, 06:35 AM   #5
wmtire's Avatar
What you have to watch out for is brake clearance, when going to a smaller diameter wheel. There is a reason it had the 18 inch OE wheels.
Even if the 17 inch wheels will clear all the brake components, they won't allow in as much air flow between the wheel and brake to help air cool it....which is going to result in your brakes running hotter and maybe wearing quicker
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 05-04-2012, 06:43 AM   #6
fonzie's Avatar
As mentioned above, it you go with 17" wheels make sure there is no issues with clearances, there should not be as 17" wheels were standard on 2004 model with 18" as option. Your mileage per gallon will decrease slightly but your ability to tow will increase by 500 lbs. Look into your owners manual for more info,
Fonzie
Old 05-04-2012, 07:11 AM   #7
acadianbob's Avatar
I can't imagine that this kind of swap would be worth the trouble and expense. You MIGHT get a slight better ride with the taller sidewall. But, you will wind up with the same diameter so no real advantage on towing power. I would definitely not make this swap. Good luck.
2018 F250 Lariat 6.2 4X4 w 4.30s, 2018 Wildcat 29RLX
2003 Yamaha FJR1300, Demco Premiere Slider
Red Green coffee mugs
Old 05-04-2012, 10:24 AM   #8
I would want to know why you are considering the down size?
whj77372 is offline   Reply With Quote
Old 05-04-2012, 11:00 AM   #9
pbrackney's Avatar
I have the Michelin LTX M/S2 "P" on my Expedition and love them. I do not really see a need for you to change rims. These tires will work perfect for you and give you a nice ride.
Philip, DW, 3 DD, 1 DS, and Ginger our Dog
2017 Wildwood 30QBSS
2003 Ford Expedition 5.4 Liter with 3.73 Axle
Equalizer 4-Point Sway 12000# & Tekonsha P3
pbrackney is offline   Reply With Quote
Old 05-04-2012, 11:46 AM   #10
dretired's Avatar
Are you looking for a higher load rating ?? I found online at discount tire or was it belle tire ?? A 18" tire for my F150 with a load rating of 3,500lbs= a 124 rating..do some searching
