Old 03-02-2013, 05:12 PM   #1
Rick R's Avatar
Today was a good day for Mods
We got our 2013 30WFKSS V Lite last October in Iowa and spent 3 days camping on the way home to South Dakota. Now we hope to tow it to Texas to visit the grandkids in April for its first real outing of the camping season. You can't go through the forums with out coming up with good ideas and since it was a balmy 60 degrees out side today I did a few of my own.
Replaced the manual jack with a Husky 4500 which required me to remove the battery box to get the jack to seat properly. Since I had the box off I decided to add a 2nd battery box in anticipation of 2 6 volt batteries sometime down the road. Next up...add some stabilizer bars to the stabilizing jacks.
ID:	24971   Click image for larger version
ID:	24972   Click image for larger version
ID:	24973   Click image for larger version
ID:	24974   Click image for larger version
Rick R is offline   Reply With Quote
Old 03-02-2013, 05:26 PM   #2
H2oski
Great job!
Wife
2007 Chevy 2500 HD 6.6
2012 Sabre 31RETS
(LA) Lower Alabama
h20ski is offline   Reply With Quote
Old 03-02-2013, 05:40 PM   #3
B47
Looks good. No snow on the ground and sunshine in S.D. - amazing.
Old 03-02-2013, 09:57 PM   #4
Looks great, time and effort well spent!
Wiscampsin is online now   Reply With Quote
Old 03-03-2013, 06:12 AM   #5
golfmedik's Avatar
Well done!
2012 Sandpiper 365SAQ weighing @ 15k, Onan, 2nd air, slide toppers, TST
2013 F350 6.7L Lariat 4x4 CC DRW,Viair 1007, Ride-Rites, Edge CTS, B&W
2001 Chevy 3500CC DRW 4x4, 8.1L, 4.10 gears w/ Detroit TrueTrac
2001 Ford Excursion Limited 4x4 7.3L,V/B Spring Mod, ProComps, Hellwig Swaybar, & other 'Necessities'
golfmedik is offline   Reply With Quote
Old 03-03-2013, 06:25 AM   #6
Wanna Be Camper
SaskCampers's Avatar
Very nice job on the box mounts. That is what make these forums so great is all the people and the thinking outside the box that makes these things a reality.
John & Deb
2011 Flagstaff V-Lite 30WRLS
Old 03-03-2013, 07:10 AM   #7
Jay Pat's Avatar
Two thumbs up!!
Pat
Jay Pat is offline   Reply With Quote
Old 03-03-2013, 09:03 AM   #8
AquaMan's Avatar
Very nicely done! Without seeming overly critical, and maybe you're not done yet, but may I add a suggestion? The plate that you are using for your batteries appears a little thin for having most of a battery hanging over the edge of the rail. Adding an angular brace down to the frame would help support that outer edge more.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
Old 03-03-2013, 09:24 AM   #9
Rick R's Avatar
Yes the bracket is 1/8" x 1-1/2". I was using what I had on hand and thought it would be to light, but it is surprisingly sturdy. It took more time to lay out the angles then to weld it so I can use 1/4 by 1-1/2 and use the old one for a pattern if I have problems with it.
One other mod I think I saw here originally. I added a spring to the propane tank hold down so it doesn't drop down when changing tanks.
ID:	25006   Click image for larger version
Old 03-03-2013, 09:27 AM   #10
Rick,can you put the Chevy tailgate down while hooked up? If not turn the motor too the side or rear. Also might drll drain holes in batt.boxs. I was tricked on both myself. Youroo!!
