Old 08-22-2010, 09:35 AM   #11
I used a recessed one from Lowes, you cut a larger hole, then a plate is used on the inside, and the holder on the outside. These "sandwich" the wall board. I used a rounded end razor knife to cut the opening, as to not cut any wiring that may be behind the wall.
bwssr is offline   Reply With Quote
Old 08-22-2010, 09:39 AM   #12
Iggy's Avatar
Hummmm. You say it is a 2 piece in the wall one. Sandwiching. I think that may work but willhave to pass my wife inspection.
I will look around at Lowes online and see what I can find.
THANKS
Old 08-22-2010, 09:42 AM   #13
Sagebrush's Avatar
Using the floor stand from Walmart. Never tips during travel. Just set it and forget it. We got the brushed metal one, but I'm already seeing rust spots on the little tin piece on the top....so maybe get the white painted one.
Sagebrush & Special K
2011 Rockwood 8285WS
2008 Chevy Silverado 2500HD
Sagebrush is offline   Reply With Quote
Old 08-22-2010, 09:44 AM   #14
Iggy's Avatar
Are you talking about like thise parts?
Old 08-22-2010, 09:45 AM   #15
Iggy's Avatar
Thanks Sagebrush. I think this is still Momma's choice.
And we know what Momma wants, Momma gets.
Old 08-22-2010, 11:17 AM   #16
Herk7769's Avatar
Times two on the brushed metal free standing one.
Works good.
HAM CALLSIGN - KC3FFW
Old 08-22-2010, 11:21 AM   #17
close, the front was the same, the part that is "behind" the wall is much wider, just enuff to fit thru the hole the holder needs. Our Wild cat didn't have a holer, and a regular one would have stuk out to far....the "closit you go in aint very roomy
Old 08-22-2010, 11:22 AM   #18
Pourme's Avatar
Works good.
x's3!
The government cannot give to anybody anything that the government does not first take from somebody else.
2003 Nash 19B
2000 F-150
Days camped so far in 2010... 20
Pourme is offline   Reply With Quote
Old 08-22-2010, 06:02 PM   #19
The Old Man
Willis's Avatar
Sorry I don't have a picture, but I bought a toilet paper rack I got at Walmart that holds four rolls. It has a top hook that will hang over most doors, but I took the hook off and mounted it to the inside of a nearby cabinet door using clips made for mounting wire closet hardware.
2010 Flagstaff 829RGSS
Still to go: AK, NL, NT, NU, YT
Willis is offline   Reply With Quote
Old 08-22-2010, 06:13 PM   #20
MrT
MrT's Avatar
Here is mod we did to hold a towel instead of drilling holes.
This is a 3M produce that used strecy stuff that can be removed. Not sure what they call it but found the large ones at WalMart in the bathroom section... Not Hardware
Iggy--we have a bunch of the 3M removeable adhesive products holding up various items in our coach, too. As for the TP, we just set a roll on the lav sink counter which is easily within reach from a seated position.
We store spare rolls on the cleaning bush handle which sits behind our toilet.
2017 Cedar Creek 38CK Hathaway Edition
2015 Ford F-350 6.7 CC 4x4
B&W RVK3300
Full-timing since 5/2/2016. Roam Sweet Home.
FROG Int'l Rallies: 2012-2017
MrT is offline   Reply With Quote
led pad
