Old 09-13-2010, 07:32 PM   #31
mjones12's Avatar
Originally Posted by Walke View Post
Hi,
Our Surveyor SP293 bathroom looks identical to yours, I shot this photo sitting on the toilet. Opening the sink cupboard door gives you some thick wood to attach a toilet paper holder, when closing the door the paper is out of the way.
Also, the solution for mounting "holders" on thin walls is shown above with a standard towel holder mounted with "butterfly" bolts, making it strong enough to grip and pull the wall down. Butterfly bolts are available at any hardware store, they come to long for thin walls but you just have to cut the bolt to a shorter length or use a shorter bolt with the butterfly nut.
Mine came from the factory mounted inside the cabinet door like that.
2018 Coachmen Apex 249 RBS
2010 Silverado LT 5.3 V8
The world is a great book, of which those who never stir from home
read only a page. - St. Augustine
mjones12 is online now   Reply With Quote
Old 06-26-2011, 09:41 AM   #32
Our 21SS bathroom is small and the included toilet paper holder and towel rack were not mounted. I guess I will mount the towel rack to the back of the door but do not know were the intended location of the toilet paper holder should be screwed to. I am leaning toward not mounting it and just keeping it in a small plastic bin to keep it off the floor and keep it dry.
Hybrid21SS is offline   Reply With Quote
Old 06-26-2011, 09:42 AM   #33
Herk7769's Avatar
We use a floor stand from Linen and things. It travels in the shower stall.
HAM CALLSIGN - KC3FFW
Old 06-26-2011, 09:52 AM   #34
Send a message via AIM to jk31668
in our 3100ss our layout made it rather easy. i just mounted the holder on the inside of the undersink cabinet so its out of sight/out of mind. just have to open the door when needed.
jk31668 is offline   Reply With Quote
Old 06-26-2011, 10:45 AM   #35
I was thinking of doing just that ! The screws that came with it are to long but I have shorter ones. I guess its either that or get a standing floor holder seem to be the best options.
Old 06-01-2012, 08:15 AM   #36
gbpacker's Avatar
Had the same problem. After looking around and thinking for a while, I came up with an ideal, solid location for the TP holder. I installed ours on the inside of the vanity door. It is solid wood and conveniently located. Just have to open the door.
gbpacker is offline   Reply With Quote
Old 06-01-2012, 08:31 AM   #37
B47
Smile
I am so impressed with all of the geniuses (sp) we have on this forum - 36 posts regarding solutions for holding toilet paper!
No wonder we got to the moon!
Old 06-03-2012, 06:31 PM   #38
Had a pc of 1/4" Lexan and cut a pc 2" wide and 8" long, drilled and countersunk 4 holes and mounted the factory tp holder to it and used double sided (outdoor) tape and stuck it on the side of the shower stall.
ID:	14756   Click image for larger version
Old 06-03-2012, 06:43 PM   #39
davidjb's Avatar
I epoxied ours inside the cabinet
davidjb is offline   Reply With Quote
Old 06-03-2012, 07:12 PM   #40
hkreck's Avatar
I personally like Robert De Niro's quote in meet the Focker's (on board bathroom go ahead on with #1 for #2 advise the driver and we'll find the closest gas station, rest area or heavily wooded area).
hkreck is offline   Reply With Quote
led pad
