Old 08-30-2016, 09:42 AM   #1
Toilet Shutoff Valve
finally got around to the "toilet shutoff valve" mod,..... since the tank level monitors aren't dependable, I look down thru the bowl to see black tank level but with the flush water flowing, it hinders me getting a good look, now can shut off that flow for a better look,.... two other benefits are (1) if we were to ever have a toilet valve leak, can now shut it off for repair or can control the use until we return home for repair, plus, (2) beneficial for boon-docking/dry camping where you can control water use at that source,.....
ID:	118822   Click image for larger version
ID:	118823   Click image for larger version
fella10 is offline   Reply With Quote
Old 08-30-2016, 09:43 AM   #2
Left Coast
Good idea....
Sent from my XT1585 using Tapatalk
Retired....but work part time as a pain in the north end of a south bound donkey.......2010 Rockwood 8280 5er....99 Dodge 2500 turbo Cummins
Old 08-31-2016, 07:24 PM   #3
How did you get that box open? Mine looks like it is stapled shut.
AbdRahim is offline   Reply With Quote
Old 08-31-2016, 08:17 PM   #4
it is stapled together and is a two piece L shaped cover over the vinyl tubing,.... on mine that cover was then screwed into the back wall with three very long screws that went all the way thru that top board and into the back wall,.... I removed the whole cover and cut out the area where I wanted to place the valve and had to add two small pieces to support the back of the "lid",... I had a little trouble with a small leak so as you see it there, I just set the cover back in place without screwing it into the back wall, so I could remove the whole cover again if the leak reappeared,... it hasn't, and the cover stayed in place during our trip this past weekend, so I'm going to leave it sitting there without screws.... the "lid" is just sitting in place also,....
Old 08-31-2016, 11:20 PM   #5
Fulltime family RVer
Love it. I've been wanting individual shut offs for all of my water outlets (toilets, sinks, shower, etc.). Haven't gotten around to doing it, though.
2012 Ram 3500 DRW/crew cab/long bed/4x4/4.10 gears pulling an early 2013 Sabre 36QBOK
Old 09-01-2016, 06:59 PM   #6
I am not the best at this stuff. I wonder if I can cut an opening with a dermal or what he best approach is.
Old 09-01-2016, 07:32 PM   #7
what you need to do to install that valve can not be done thru a small opening like is under that lid,...... the long wooden cover needs to be removed out of the way, it is just two boards, the front one and the top board,...... it is screwed into the back wall by three or four screws thru that top board and into the back wall, when they are removed the whole cover can be removed in one piece,...... then the tubing is accessible and you can do everything you need to do to install the valve,..... then cut the top lid at the correct position so the valve will be under it when the lid is removed,......
Old 09-01-2016, 08:59 PM   #8
Thanks fella 10
Old 09-07-2016, 01:29 PM   #9
tool to open/close valve
Thanks fella 10
AbdRahim,..... if you do this mod, I wanted to add this,.....trying to turn that valve handle, by reaching down into that small opening can be difficult,..... your valve may differ, but the valve I used is a 1/2" pvp valve from Lowes and I cut down/shortened the ears of the black handle so it could turn 90deg. inside that channel without a problem,..... I made the tool pictured below and can grab it in hand to turn the valve handle, I decided to not add a t handle at the top of the pipe so it would fit inside that channel and I could store it there with the valve,....
ID:	119661   Click image for larger version
ID:	119662   Click image for larger version
Old 09-09-2016, 09:37 PM   #10
very creative
