Old 06-12-2012, 02:05 PM   #21
FreedomTracker's Avatar
Question
Do these covers have any positive effect on everyday gas milage..?
2012 Ford F150 4x4, 5.0L, 3.55
2011 Rockwood MiniLite 1809s
E2 WDH 600/6000lbs
FreedomTracker is offline   Reply With Quote
Old 06-12-2012, 02:14 PM   #22
ironj's Avatar
I used to always say yes......that is untill someone much smarter than i thoroughly dispelled my belief with fancy charts, diagrams, and even a " wind model'......althought the application was not a towing scenario?....possibly diff in that case.....
2015 F350 Platinum Fx4 6.7 Diesel Dually. B&W turnover, B&W Companion, air bags and wireless controller.
2015 Heartland Road Warrior 420 Rt
2012 f250 Fx4 6.7 Diesel crew cab tinted n tuned
2012 lacrosse 318bhs touring- sold
ironj is offline   Reply With Quote
Old 06-12-2012, 02:29 PM   #23
TURBS's Avatar
I have a roll up vinyl cover that velcros down the sides and positive latches at rear.
Three years old and no issues.
I pull a 5er and roll it up when towing and roll it back out when not.
It clears the 5er plate no problem.
Old 06-12-2012, 02:34 PM   #24
Nope. Mythbusters did an episode on this. The only technique that showed an improvement was using a mesh tailgate. Explanations in the link:
Annotated Mythbusters: Episode 64: More Myths Revisited
SCOC is offline   Reply With Quote
Old 06-12-2012, 02:49 PM   #25
ironj's Avatar
should have known those guys would have done an episode on that! haha...although i read the link, and they also just tested mileage during "normal" driving...so i am still left to question if the same results would be generated while towing a "sail" of a TT behind the vehicle???...hmm...maybe ill email them!
i mean if two cars can draft off each other and improve mileage, i have to wonder how a tt affects a vehicle and moresoe than that, how a bed cover would play into that??...
Old 06-12-2012, 02:56 PM   #26
TURBS's Avatar
It would help the guy right on your tt bumper but not you.
Old 06-12-2012, 03:16 PM   #27
ironj's Avatar
why not?...i admit my drafting experience is limited while towing while racing my fellow campers (lol) but why would not the same theroy that allows the high pressure air from the front of a nascar or other "drafter" to push higher pressure air foward on the lead vehicle not apply?.....lack of spoiler? not enough speed? i honestly dont know....??
and im still on the fence as to the benefit or not of a bed cover while in a towing situation....aerodynamics are complicated.....and my studies were in biochemistry...LOL
in the end i imagine that any benefit, if there even is one, is probably miniscule at best! Thats my theory and im sticking to it!
Old 06-12-2012, 03:34 PM   #28
TURBS's Avatar
Look over the cab of you tv roof from the front and if you see a big white tt sticking up in the air higher than your cab you just seen the bigist hole in your theory.
Ever heard of a high low camper?
Now that might have a chance.
Anytime you tow anything that sticks out further than the tv punching the hole in the air you have drag.
A bed cover won't make a difference.
Old 06-12-2012, 03:35 PM   #29
Access Roll-Up Cover Rack Combo
have one of these .. although i can see it not being great for a 5er, it does have its advantages when not pulling. i pull an Aframe A122, and use the rack system to bring along my canoe, or bikes when the need be.
very well engineered, easy on and off... and the racks store up in the rafters of my garage.
Tonneau is still in great shape, never adjusted after 4 years. Treat it with 303 and it will probably be your friend for life .
d-mo
2008 Nissan Frontier 4x4
2011 Rockwood A122
D-mo is offline   Reply With Quote
Old 06-12-2012, 03:50 PM   #30
Another rat in the race
jar3316's Avatar
I have a Tonno Pro and it works great vinyl with a metal frame and folds into 1/3s and latches at the front. Best part is its light weight and I can get it on or off by myself in less than 5 minutes. No really.
for gas mileage I don't notice a difference, but to be fare my truck gets 10 mpg all the time no matter what. Every now and then I get 14mpg if I drive the whole tank on the freeway with no large trailer and cruise control the whole time, cover or no cover.
But from the engineering stand point. The "bubble" of circulating air in an empty bed would help get the wind up and over the TT but anything in the bed or a 5th would disturb the bubble. I don't think the gas mileage would be increased by much anyway, maybe even not enough to measure outside of a lab.
A rainy day camping is better than any sunny day at work
2004 F250 V10 SD Xcab 2011 Wildwood T26BHXL
jar3316 is offline   Reply With Quote
led pad
