Old 04-09-2012, 02:48 PM   #21
If your unit dosen't come with an electric toungue jack that would be high on my list. Next would be a Tornado black tank flush system. Easy to install and worth every penny. That will get you close to the $250 for those 2 items.
2012 Grey Wolf 19RR
2008 Dodge 2500 CTD
Nights camped 2012 - 35
Nights camped 2013 - 46
rkswyo is offline   Reply With Quote
Old 04-09-2012, 03:00 PM   #22
Wanna Be Camper
SaskCampers's Avatar
Just from the point of view of safety, I cannot see spending $250+ an additional 10 bux on anything but a TPMS system. $259.00 bux buys you a very nice system and with all the blow outs there seem to be, it should be at the top of everyones list and if any of the manufacturers are reading this just put it on the trailers you just seem to have to put substandard tires on and give us all some peace of mind. A power tongue jack or black tank flusher will do you no good if half the insides are tore out of your rig from a blowout. Oh and I am guilty of buying a power jack before the TPMS system as well, you know convience before safety.
John & Deb
2011 Flagstaff V-Lite 30WRLS
Days Camped 2016: 3 2017: 0
Old 04-09-2012, 03:27 PM   #23
DAISY BOYKIN's Avatar
Well, let me see?????????
1. Installed Gas pistons on all the cargo doors.
2. Solar tinted all the windows.
3. Installed hot water tank A/C remote switch with pilot light.
4. Installed battery disconnect switch.
5. Remove white rusty scare lights, replaced with with stainless rim lights.
6. Removed front door side light (yellow one) replaced with auto digital
auto light.
7. Removed 1/4 X 20 bolt at top of awning, replaced with SS eye bolt to
secure awning on windy day.
8. Replaced frosted (no see thru) glass in both doors with with grey tint
glass.
9. Replace all cargo door locks with barrel locks (round key type)
10. Removed all under belly white vents, installed nylon screening over
hole, reinstalled white screen vents (keeps the bugs out)
11. Removed all rocker switches in control panel, switched wires so when
you push top of switch bump out will go out, push bottom, bump out
will come in.
12. Installed 110VAC outlet near countertop in kitchen for coffee pot short cord.
13. Relocated snap strap nearer front of table top on dinning table slideout for greater access.
14. Replaced rear kitchen gray tank dump valve with remote valve for
greater access.
15. replaced all warning decals on out side with engraved plates.
16. Installed shelf in cabinet above fridge.
17. Replaced stove top burners igniters with battery controlled device.
Tomorrow I will have to finish my list
Sid, Lois & HRH MISSY Terrible 2s SHIH TZU
2011 ROCKWOOD 8285 WS
2014 F-250 KING RANCH PS/SD/6R140/BFT
DAYS CAMPED 2018 21 DAYS
DAISY BOYKIN is offline   Reply With Quote
Old 04-09-2012, 03:50 PM   #24
OPPS, I went back and read the post
I was only suppose to list the top three, sorry!
Old 04-09-2012, 04:06 PM   #25
On my 2011 minilite I have done a few improvements like. 1: Repairing all the large gaps on the cabinets with moldings from Forest river . 2: I replaced the curtains valances because they were looking very cheap and flimsy < and we installed some curtains lines because th 2011 models were discontinued. 3: I installed some moulding at the bottoom of the shower to prevent water leaks. 4: I installed a fan for cooling on the fridg to prevent the OE fan to cycle all the time special;ly at night when I sleep.
ID:	11909   Click image for larger version
ID:	11910   Click image for larger version
ID:	11911   Click image for larger version
ID:	11912   Click image for larger version
capucine is offline   Reply With Quote
Old 04-09-2012, 04:19 PM   #26
I forgot to add some shower curtains hooks to replace the terribly ugly ones and a new shower hose and head to replace the stiff no fun to use plastic hose with a stainless steel one. A shut off valve was installed just over the shower handles. Like that it is very easy to control the valve while showering.
ID:	11914   Click image for larger version
ID:	11915   Click image for larger version
Old 04-09-2012, 08:48 PM   #27
Mark and Linda's Avatar
Most of my mods have been repairs. I started at the tongue with the wiring and have insulated it all the way back to the tail-light. I added some clamps and stand offs to keep it up and out of the way where it might rub. Preventive measures..
I did replace the shower head with one that is adjustable and has a shut-off. On my 2009 Puma I added two CD cases under the entertainment center to hold CD's. I also fixed the divider where it would be easier to remove when the power cord gets tangled up behind it. Right now I am concentrating on the nuts and bolts.....
2009 Palomino Puma 25RS
2007 Chevrolet Silverado
Prodigy P2 Brake Controller
Mark and Linda is offline   Reply With Quote
Old 04-10-2012, 10:24 AM   #28
miatared's Avatar
Originally Posted by Cincy6 View Post
Herk- I checked out the antennaweb site and was wondering if anyone knows of an Android App that would do something similar
Have a look at TV Antenna Free - decent app for Android devices.
Denis & Diane
2010 Sabre 31REDS
Ford F-250 2011
* Happy Campers *
miatared is offline   Reply With Quote
Old 04-10-2012, 10:33 AM   #29
jjm901's Avatar
DW and I looked over all these great mod ideas and pulled the trigger on the Barker VIP 3500 electric tongue jack, a shower curtain rod extender, and the oxygenics shower head. Keep the mods you are happy with coming though, love getting the different ideas.
2013 Ford F150 Super-Crew
2014 Heritage Glen 312qbud
jjm901 is offline   Reply With Quote
Old 04-10-2012, 11:35 AM   #30
You will be glad you did the power jack. Makes hooking up and leveling so much easier. I would hate to be without one.
2012 Grey Wolf 19RR
2008 Dodge 2500 CTD
