Old 03-14-2008, 05:07 PM   #1
Bona fide Nut job
Winsurfer76's Avatar
Tornado Rotary Tank Rinser
I recently purchased a Tornado Rotary Tank Rinser for my Wildwood. The instructions say to mount opposite of the outlet. The way my tanks are situated, the opposite end is covered by the frame rail. Would it hurt to install it on the side of the tank as far towards the end as I could?
2005 Wildwood 28BGSS
Winsurfer76 is offline   Reply With Quote
Old 03-14-2008, 05:46 PM   #2
milzat's Avatar
I installed mine on the drain side. It's the only place I could mount it. It works fine. Does a very good job flushing the tanks.
As a note, I did drill the holes out a bit larger in the nozzle to create more flow.
Test it by connecting to a garden hose before installing to check the spray pattern.
milzat is offline   Reply With Quote
Old 03-14-2008, 05:55 PM   #3
Bona fide Nut job
Thanks for the information. I'll take your advice about the enlarging the holes as well.
Old 03-14-2008, 09:38 PM   #4
powerboatr's Avatar
me to i put mine in the middle of the tank and as high up as i could drill
it seems to work A OK
so far
and makes a neat whirring noise when its cleaning gunk
Living in the Piney Woods of Texas.
powerboatr is offline   Reply With Quote
Old 04-04-2008, 09:54 PM   #5
wildwood's Avatar
i didnt get any operating instructions with the tornado
do you dump black, then gray tanks and then use tornado to rinse tanks and dump,
wildwood is offline   Reply With Quote
Old 04-07-2008, 03:53 PM   #6
MaxRock's Avatar
Send a message via Yahoo to MaxRock
I had to install the tornado on the same side as the dump valve. That was the only place I had accessible.
'04 Wildcat 29BHBP
'02 Chevy 2500HD
DMax/ZF-6 Speed, CCLB, 0-70-110 HP VA Tuner,
5" exhaust, H2 Tires/Chrome Wheels (315x70-17),
B&W GN hitch and 5th Wheel Companion,
BrakeSmart Brake Controller
http://www.dieselplace.com
http://www.LSUsports.net
MaxRock is offline   Reply With Quote
Old 08-09-2012, 01:08 AM   #7
gbpacker's Avatar
I had a tornado installed when I purchased my trailer.
In uses, I dump both gray and black water tanks. Then close the dump valves and flush with the tornado for about a minute, before opening the dump valve. This approach seems to clear material stuck to the bottom of the tank.
gbpacker is offline   Reply With Quote
Old 08-09-2012, 07:25 AM   #8
Every tank has its (Own) way of cleaning,dumping,flowing. Placement of rinsing device,angle of tank at dump station,fore & aft, water pressure applied to rinsing device,Ect. Place a Clear elbow at discharge and try different methods,you will see the results! Youroo!!
youroo is online now   Reply With Quote
Old 08-09-2012, 08:00 AM   #9
BlakeB's Avatar
I installed the Tornado about 1/2 way back on the side of the tank because the opposite end was not accessible either. It works awesome.
Here's what I do...
1. Empty black tank
2. turn on tornado for about 5min(usually lots of toilet paper still comes out)
3. shut black tank valve and let tornado put a couple gallons in
4. Open grey valve to clean out sewer hose
This usually works well for me...
ID:	17747   Click image for larger version
TT = 2014 Palomino Solaire Eclipse 318TSBHK
TV = 2014 Ram 2500 Big Horn 6.4L V8
Pit Crew: DW (Robin)
Kids: 3yo DD (Riley), another DD cookin (Kennedy)
Security: 5yo Boxer (Sasha), 14yo yorkie (Porter)...he was married in
BlakeB is offline   Reply With Quote
Old 08-09-2012, 09:07 AM   #10
I have installed several of the Tornado tank rinsers. I have always tried to put them in the center of the tank on the side. Outlets for the drain have always been on the end. This has worked well for me. Honestly I would not be without the Tornado. In my opinion it is one of the best mods you can do.
2012 Grey Wolf 19RR
2008 Dodge 2500 CTD
Nights camped 2012 - 35
Nights camped 2013 - 46
rkswyo is offline   Reply With Quote
