03-14-2008, 05:07 PM
Bona fide Nut job
Tornado Rotary Tank Rinser
I recently purchased a Tornado Rotary Tank Rinser for my Wildwood. The instructions say to mount opposite of the outlet. The way my tanks are situated, the opposite end is covered by the frame rail. Would it hurt to install it on the side of the tank as far towards the end as I could?
2005 Wildwood 28BGSS
03-14-2008, 05:46 PM
I installed mine on the drain side. It's the only place I could mount it. It works fine. Does a very good job flushing the tanks.
As a note, I did drill the holes out a bit larger in the nozzle to create more flow.
Test it by connecting to a garden hose before installing to check the spray pattern.
03-14-2008, 05:55 PM
Bona fide Nut job
Thanks for the information. I'll take your advice about the enlarging the holes as well.
03-14-2008, 09:38 PM
me to i put mine in the middle of the tank and as high up as i could drill
it seems to work A OK
so far
and makes a neat whirring noise when its cleaning gunk
Living in the Piney Woods of Texas.
04-04-2008, 09:54 PM
i didnt get any operating instructions with the tornado
do you dump black, then gray tanks and then use tornado to rinse tanks and dump,
04-07-2008, 03:53 PM
I had to install the tornado on the same side as the dump valve. That was the only place I had accessible.
'04 Wildcat 29BHBP (Sold)
'02 Chevy 2500HD 415k miles as of Dec-18
DMax/ZF-6 Speed, CCLB, 0-70-110 HP VA Tuner, 5" exhaust, H2 Tires/Chrome Wheels (315x70-17),
B&W GN hitch and 5th Wheel Companion, BrakeSmart Brake Controller
08-09-2012, 01:08 AM
I had a tornado installed when I purchased my trailer.
In uses, I dump both gray and black water tanks. Then close the dump valves and flush with the tornado for about a minute, before opening the dump valve. This approach seems to clear material stuck to the bottom of the tank.
08-09-2012, 07:25 AM
Every tank has its (Own) way of cleaning,dumping,flowing. Placement of rinsing device,angle of tank at dump station,fore & aft, water pressure applied to rinsing device,Ect. Place a Clear elbow at discharge and try different methods,you will see the results! Youroo!!
08-09-2012, 08:00 AM
I installed the Tornado about 1/2 way back on the side of the tank because the opposite end was not accessible either. It works awesome.
Here's what I do...
1. Empty black tank
2. turn on tornado for about 5min(usually lots of toilet paper still comes out)
3. shut black tank valve and let tornado put a couple gallons in
4. Open grey valve to clean out sewer hose
This usually works well for me...
TT = 2021 ROO 233S
(Previous)TT = 2014 Palomino Solaire Eclipse 318TSBHK
TV = 2016 F-150 5.0L SCREW
Pit Crew: DW (Robin)
Kids: 9yo DD (Riley), 5yo DD (Kennedy)
Security: Boxer (Harley), yorkie (Willow)
08-09-2012, 09:07 AM
I have installed several of the Tornado tank rinsers. I have always tried to put them in the center of the tank on the side. Outlets for the drain have always been on the end. This has worked well for me. Honestly I would not be without the Tornado. In my opinion it is one of the best mods you can do.
2012 Grey Wolf 19RR
2008 Dodge 2500 CTD
Nights camped 2012 - 35
Nights camped 2013 - 46
08-09-2012, 09:53 AM
Seems this mod isn't getting great reviews on Amazon. A lot of people are saying the head will barely rotate when water is hooked up. Anyone else seen this issue with theirs?
08-09-2012, 10:44 AM
I have had them on three different trailers and have never had a issue with any of them. My guess is faulty installation.
2012 Grey Wolf 19RR
2008 Dodge 2500 CTD
08-09-2012, 01:14 PM
They're are saying they test them before installation and they don't work like they should.
08-09-2012, 01:22 PM
I have used it for two years now and it is working great.
2015 Dodge Ram 1500 Quad Cab 4WD w/trailer pkg
345HP 5.7 Hemi/8spd Auto/3.73 Rear
2010 Roo 23SS
Prodigy Brake Controller
Equal-i-zer WD Hitch
2003 Harley FXDX Super Glide
08-22-2012, 10:12 AM
I have been contemplating this mod as well for my Surveyor 255RS. I think the only viable spot to mount is near the sensors. I think I have seen pictures of others doing this but are there any concerns with this.
From some internet reading, some have said that water pressure has destroyed the nozzle and broken things off inside the tank. Should a pressure regulator be added or is it just a matter of controlling the hose pressure at the valve?
08-22-2012, 11:29 AM
I have read that too but have not had any issue yet. The directions even state to turn water on gradually. I have just turned it on slowly and up to about 3/4 of the way on. This has worked great for me. You can actually hear the nozzle spinning and spraying in there.
TT = 2021 ROO 233S
08-22-2012, 08:45 PM
The city dump station that I use has seriuos pressure on the water hose. I have yet to have a problem. As Blake mentioned, I turn the water on slowly. I would not be without my Tornado. One of the best mods you can do.
2012 Grey Wolf 19RR
2008 Dodge 2500 CTD
08-22-2012, 09:02 PM
I too could only mount it in the side of the tank. I have the quickie flush (no spinning assembly). I installed it toward the back of the tank on the side. works great. I would always install one in any black tank!
08-25-2012, 08:27 PM
2012 F-350 4x4 King Ranch Super Duty CC 6.7 Turbo Diesel 3.55 e-locker
2011 Palomino Puma 30KFBDS with Side Paw Kitchen and Bunkhouse
Equalizer E2 Hitch
08-25-2012, 09:18 PM
Originally Posted by GASPEDDLER
Looks perfect....enjoy!
TT = 2021 ROO 233S
