Old 04-12-2015, 02:23 PM   #1
campfirefun's Avatar
tow vehicle generator
Does any compnay make a generator kit that can be added to your vehicle engine to run a make it a generator also While idling. Yes i know thats not great for vehicle to idle but just looking at this idea. Why I ask is we tow with a van and it would be cool to run the air when we pull over for lunch, rest etc. since we have a van it would pain to carry around a generstor that would power up a 12000 btu unit if I pulled with a truck I would just put it in the bed but a few years away from that with four kids. The van is the best option right now.
campfirefun is offline   Reply With Quote
Old 04-12-2015, 03:33 PM   #2
jtstromsburg's Avatar
A really big inverter? Something like this maybe? http://www.tripplite.com/power-inver...lets~PV3000HF/
I would think most alternators wouldn't hold up though, but maybe?
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is offline   Reply With Quote
Old 04-13-2015, 07:53 AM   #3
An inverter is actually a good idea. It could be added to the camper itself. One large enough to power the AC will definitely draw a ton of power off the battery. If you limit yourself to quick 1-2 hour stops max you could probably get away with a couple Group 31 deep cycle batteries. The charge wire from your TV would charge them back up while driving as well as helping a little at idle while stopped. Some type of transfer switch/relay would be necessary to prevent powering from shore and inverter at the same time. I have a bit of experience with inverters on boats for powering electric grills and even air conditioners. The systems and components are very similar. PM me if you have any specific questions.
2013 Solaire Eclipse 317BHSK 2009 Denali XL Tow Vehicle with Equalizer distribution and sway control
PMickey is offline   Reply With Quote
generator, tow vehicle
