Old 06-25-2012, 11:06 AM   #1
Chewie's Avatar
Towel drying rack
This may have been done before, but I was looking for a drying rack to mount and CW had some for $36+. I was at home depot this morning and came up with this. Cost about $6-7. I made it so the base is on the bumper and pulls apart for storage. 1/2" schedule 40 PVC, assorted fittings left over paint and clothes line. No rust or permanent mounting and no drilling. Was tired of drying things off the awning.
I used to have a really nice motorhome
2016 Jeep Wrangler Unlimited
Chewie is offline   Reply With Quote
Old 06-25-2012, 12:33 PM   #2
B47
That looks like a nice easy thing to assemble, use and then disassemble when done.
One question - some CG's prohibit the drying of laundry outside - you think this would cause some problems with the neighbors?
B47 is online now   Reply With Quote
Old 06-25-2012, 12:36 PM   #3
Chewie's Avatar
I guess we will see how the CGs react. I'm not going be doing laundry or hanging drawers up. This is for beach towels instead of draping them on our awning frame. Shouldn't be offensive to other campers.
Old 06-25-2012, 12:53 PM   #4
Chuckinca's Avatar
Neat idea!
What value was painting the white PVC pipe and fittings black?
2018 Flagstaff 29KSWS
2008 Ram Laramie 3500 Megacab 4x4 Cummins 6.7L Turbo Diesel
Chuckinca is offline   Reply With Quote
Old 06-25-2012, 01:32 PM   #5
crushor's Avatar
Very nice. I was thinking about getting one of those later this year. Hmmm, new project.
2007 Ford F250 4x4 Harley-Davidson Powerstroke
2006 Cedar Creek Silverback - 35 LRLBS
(2012 -11) (2013 - 10 so far)
crushor is offline   Reply With Quote
Old 06-25-2012, 01:41 PM   #6
B47
Probably not - once again - neat looking rack.
Old 06-25-2012, 11:35 PM   #7
Great idea, Let's post the supply list and the dimensions to build this rack ?
jiggerk is offline   Reply With Quote
Old 06-26-2012, 06:12 AM   #8
Mark and Linda's Avatar
Neat looking mod...might try making one. My neighbor has a Cameo 5'r. He made me a towel drying rack that would fit onto the ladder. He brought it over the other day to give it to me then realized I didn't have a ladder. I didn't want to go install a ladder so it would attach so I told him, I appreciated it but maybe one of his friends might be able to use it.
2009 Palomino Puma 25RS
2007 Chevrolet Silverado
Prodigy P2 Brake Controller
Mark and Linda is offline   Reply With Quote
Old 06-26-2012, 09:19 AM   #9
Although not the same as OP here's a couple links to some plans I found:
RV PVC Laundry Ladder Rack Plans - Instructions
PVC Drying Rack
Old 06-26-2012, 12:18 PM   #10
Chewie's Avatar
Ok here's the list of what I used (already had PVC primer and glue):
1/2" schedule 40 10' length
8- 1/2" 90* elbows
2- 1/2" T fittings
2- 1/2" 45* elbows
To fit the 4" box bumper I cut 4 pieces of PVC 3 1/2 inches for each mount(8 total 3 1/2" pieces.).
(As you can see in the pic the 3 90* elbows and the t fitting fit over the bumper and the uprights have the 45* elbows that join to the bumper mount.)
Then I cut 2- 1 1/2" pieces to join the uprights to the bumper mount with the t fitting and 45* elbow.
Uprights are 29 1/2" each, and the top cross brace is 30" joined by the 90* fittings. Very easy to make or adjust measurements but I used the entire 10' section. I glued all fittings except the 45* to the t fitting so I can disassemble the rack and store it inside. The reason i painted it black was because I was messy with the purple primer and that on the white looked like junk. So I had left over paint and wallah. To drill the holes for the clothes line I taped the 2 uprights together( my clamps would securely hold the 2 pipes) and used a small bit for a pilot then followed up with a 1/4" bit. It took about 25 minutes to make. I didn't have any official drawings or design. It was winging it off the top of my head off similar racks. So if this thing fails miserably down the road I'm not out a lot of time or money.
