06-07-2010, 07:46 AM
Towel Rack
Need to put a towel rack in the bathroom - but I am anxious about putting screws in the walls. I have the aluminum studs so "finding a stud" like you do in a home is not an option. What about the interior walls vs. exterior walls? Screw length, etc.? Any comments appreciated!
2012 Puma 30FQSS
2005 Ford F-250 Super Crew 6.0 PSD
2003 Honda Odyssey
1 wife, 1 son, & 1 cat
Volunteer Firefighter/EMT
Asst. Scoutmaster (BSA)
06-07-2010, 07:48 AM
We just hung an over-the-door rack on both sides of the bathroom door.......1 for the bathroom towels, and 1 for the kitchen towels and hot mats.......works great.
06-07-2010, 08:39 AM
We did the same thing.
06-07-2010, 08:41 AM
x3
Tom and Margaret
2014 Berkshire 390bh-60
06-07-2010, 11:12 AM
x 4 only I fastened our towel rack to the inside of the bathroom door.
Everett & Joan after 60 years together. 2004 1/2 ton Chevy & 2011 Rockwood 1809S
Number of nights camped in 2012 65
Number of nights camped in 2013 82
Number of nights camped in 2014 105!
Number of nights camped in 2015 81
06-07-2010, 11:22 AM
I went to Home Depot, in the closet solutions and storage section they have Closet Maid shelving, I bought the 12" shelving and the option for a clothes hanger rod, they have all sorts of options and mounting solutions, I hung two shelves above the toilet and the clothes hanger rod on the bottom shelf, I use the shelving to store all the clean towells, and any moist towell I can hang on the clothes hanger rod. Typically the racks have a lip that hangs down on the front, it provides strength for the span of the shelving, I mounted it upside down (lip up) and it keeps anything from slipping off the shelving, works great, provides storage and a towell rack for drying
x5 Have used over-the-door towell racks from the beginning. I also have a free-standing folding towell rack that we use outside or inside.
06-07-2010, 11:39 AM
x6, plus we put 2 tension shower rods over the 'tub'.
Don and Laura + Roo
Chesapeake, VA
06-07-2010, 06:14 PM
Cunning Linguist
Same .....
We have "trailer towels" that we leave in the unit all the time.
We put individual clean/dry towels in small "spacebags" (vacuum pack/seal) and have them hanging packaged from the 3M adhesive hooks on the bathroom wall to save room. Then we have an over the door rack to hang the towels we are currently using or wet stuff that we don't put outside on the retractable clothes line.
We can store 5 bath towels, 5 hand towels and 3 beach towels on the inside bathroom wall, without using up any closet/shelf space (which is a godsend space saver in a 19' TT.
The towels take up a lot less space when they are vacuum packed, and will stay clean/dry/fresh indefinately in the bags.
Probably not the "prettiest" solution .... but we rarely get guest stopping by and asking to inspect our trailer bathroom ;-)
06-07-2010, 06:29 PM
The depot el cheapo chrome towel racks. Screws in the thin walls and door no problem.
06-07-2010, 08:59 PM
Thanks to all - we have the over the door deal going on as well. Just wanted one more in the bathroom (for like a hand towell only). Will check them out at HD/Lowes.
2012 Puma 30FQSS
2003 Honda Odyssey
06-07-2010, 09:36 PM
Cyber Phrenologist
That's what we did and it turned out great. Just take it easy and don't strip out the screw hole. And I only used the inside walls, not the outside. I put one el cheapo rod on each end of the toilet room to hold 4 large towels. If a towel is damp the fan will help dry it faster.
KU4OJ
2008 (or is it 2009?) Rockwood 8280SS - 2022 F-250 7.3L
06-08-2010, 12:20 AM
If it's just a hand towel "ring" type of hangar then you can get away with installing them into the thin paneling. We did this above our sink in the bathroom. Ours also didn't have a TP holder so we installed one on the wall next to the toilet (exterior wall) using the plastic drywall anchors. Since the exterior walls have the thick styrofoam in them the anchors hold well. A small dab of Gorilla glue in the holes with the anchors will ensure that they can never pull out.
06-08-2010, 11:12 AM
We bought a kit with Hand towel Ring, Bath towel bar, TP bar, and Robe hook. Installed them all on the interior walls of our bathroom and it makes a big difference.
I used sheetrock fasteners.
Nights camped in 2010 = 21 nights
2008 Chevy CCab 5.3L 4WD Z71
2008 FR Surveyor 291
Champion Genset
Slpybear, Mrs Slpybear, Three Cubs
09-15-2010, 06:48 PM
Towel Holder - Solid on thin wall -Butterfly bolts
Hope you can read this, it is a step by step install of a Towel Holder using "butterfly" bolts. I do not know their technical name, you drill a larger hole than you would like but they are solid. Just resolve to never removing the holder. They come with very long bolts, you have to cut them or use a shorter bolt, I recommend the 1/8th size, they will install any holder. After these wings spring inside the wall you pull the holder toward you and tighten the bolts. With four of these bolts installed your kids /grand-kids can swing on it.
Ken & Judy
2012 Prime Time Lacrosse 301RLS
2014 Ford F-150 Lariat - Max. Tow - Ecoboost
Hensley Arrow Hitch
Average 50-60 nights/yr
09-15-2010, 07:21 PM
Goop
I use this product to attach most everything to interior/ exterior walls and in shower unit. A real slick surface needs a little abrasion or the suction will fail. Nice part, if you want to move the rack, close hook basket, unseal and peal the goop off leaving no trace. This meathod has worked for me for over a year with the only failure being in the shower.....I neglected to scratch the surface of the wall and suction cups of a soap dish so they could get a good hold on the GOOP. Duct tape and GOOP, my friends.
"If everything seems to be going well, look around, you've obviously overlooked something."
09-15-2010, 07:57 PM
Dual Towel Rack - My Photo Gallery
easy to find the studs, press on the walls until you find a firm spot
2010 Rockwood 8281SS Signature Ultra Light
2009 Dodge Ram 2500 w/6.7 Cummins
09-16-2010, 02:49 PM
Ditto. WE used the drywall anchors and put up the whole kit... Towel bar above toliet in thin wall, Toilet paper ring on vanity, and robe hook on door.
Champion Genset
