Old 01-15-2014, 10:22 AM   #21
acadianbob's Avatar
Originally Posted by befink View Post
We are looking at purchasing the same Shamrock 233s - So I'm guessing we will need equalizers to tow it with our 2007 Nissan Aramada? Was hoping we could get away without having to buy them.
It would be a huge mistake and safety risk to forgo a WD hitch with sway control.
2018 F250 Lariat 6.2 4X4 w 4.30s, 2018 Wildcat 29RLX
2003 Yamaha FJR1300, Demco Premiere Slider
Red Green coffee mugs
Old 01-15-2014, 10:27 AM   #22
MegaTracer's Avatar
I pull a Tracer 3150BHD with my 2007 Armada. I have the Equalizer brand hitch and it tows beautifuly! I highly recommend it. Very easy to hook up and detach for towing. Anything over 5,000lbs Nissan requires a weight disro hitch according to the manual. Electric brakes too.
Things to know about your Armada is there is a "big tow package" option that allows you to pull up to 9100lbs. An easy way to tell is you will have a transmission cooler gauge and load leveling suspension. Without that I believe the towing capacity is between 6,300 and 7,300 lbs depending on gearing.
Good luck with your purchase!
MegaTracer is offline   Reply With Quote
Old 01-15-2014, 11:10 AM   #23
bayoubuggie's Avatar
TracerMada, I have the 2950 which has a similar tongue weight. I'm looking into the equalizer hitch, can you tell me what weight bars you have?
2014 PT Tracer 2950 BHS
2008 Chevy 1500 CC
bayoubuggie is offline   Reply With Quote
Old 01-15-2014, 12:30 PM   #24
Platokidd's Avatar
I use mower guard on the L brackets and spring bars at contact points.
It embeds into the metal over time. The best part is no mess.
MowerGUARDâ„¢ - Graphite Undercoating for Mower Decks and Blades
Good grease on the bar socket pivot points and ball.
The noise dont bother me , scares the heck out of the woman but I get I kick out of that!
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
nights of camping
2017-67 / 16-92 / 15-73 / 14-60 / 13-33
Seasonal
Old 01-15-2014, 01:00 PM   #25
bikendan's Avatar
befink, if you would read your owner's manual towing section, it would state the amount of hitch weight that would require using a WDH. anything at or above that amount, would need one.
i'm sure that the 233S's hitch weight would require it, especially with a soft suspended SUV.
the best WDH's have built-in sway control, such as the Equal-i-zer or Reese Dual Cam.
the ones with add-on friction anti-swar bars, are old technology and are a hassle.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 01-15-2014, 03:05 PM   #26
MegaTracer's Avatar
I run the 10,000lb bars. They are good for 1,000lbs of tougue weight. My Armada is limited to 900lbs. My tracer is close to 700lbs if tongue weight
Old 01-20-2014, 09:27 AM   #27
So signed all papers for the 233s at the dealer this weekend.
Picking up next weekend, because we had snow...
But they reccommended using the Reese round bar WDS with 800 lb bars ($600), they said Dual Cam is extreme overkill for this size trailer?
Thoughts???
befink is offline   Reply With Quote
Old 01-20-2014, 10:35 AM   #28
I pulled my Roo19 (~4600lbs) with a Chevy Traverse (5200 lb capacity) for a year and realized it just didn't have the oomph and bought the Silverado. I did have a WDH. One day I that first year I decided to pull the trailer over to the storage lot (about 5miles) w/o hooking up the bars on the Traverse. HUGE DIFFERENCE. It convinced me!
2011 Traverse LT, 3.6L, FWD
Old 01-20-2014, 12:15 PM   #29
bikendan's Avatar
Thoughts???
IMHO, i would never tow a full height trailer w/o a wdh with built-in sway control, so it's not overkill.
I tow the 23SS w/the Equalizer with the 1000lb bars and it's definitely not "overkill".
Old 02-10-2014, 03:04 PM   #30
cogito ergo moo
Cowracer's Avatar
I tow a smallish 21ssl with the king of the SUV's (Diesel Ford Excursion) and I wouln't dream of hauling it on a public road without WDH and sway control. I'd rather go without trailer brakes than without the WDH and sway, and I aint about to go without trailer brakes. LOL!
nobody ever found themselves wrecked in a ditch going, "Man, I had too much hitch on this rig"
Tim
FROG Member MO-0008-571 Since 20124444444444My Project Blog: https://cowracer.blogspot.com/
2016
Rockwood Signature Ultralite 8329ss
Rallies Attended:
Cowracer is offline   Reply With Quote
