Old 02-24-2014, 11:11 AM   #11
Helmsey's Avatar
Originally Posted by EXGMTech View Post
and what would you cut the bumper with?...pretty thick stuff!
We must have different bumpers, mine is not the most stout thing in the world. Im betting a sawzall would make quick work of it.
Originally Posted by Capt. Mike View Post
No more often than we need backup lights on our trailer, I just got 4 of these from Harbor Freight (on sale at $2.99 ea) and stick them on the back bumper if I'm trying to back unto a site after dark. They have a magnet on the back - not strong, but strong enough to stay on the bumper as you slowly back into a space.
We've got a few of those strategically placed, but not near as "custom" as flushing them into the bumper
It's on my to do list that isnt very important right now but will likely give it a whirl at some point this summer.
2015 Chevy 3500HD
2013 Sandpiper 365SAQ
Helmsey is offline   Reply With Quote
Old 02-28-2014, 08:12 PM   #12
transamz9's Avatar
Guys I know some of you are not going to want to spend the money because like me I try to not have to back in after dark but sometimes when things go wrong you might get there late. If you want some back up lights check these out that I put on our heavy haul truck.
This is what I put on my boat (much cheaper)
2005 Ram 5.9 AT SB QC (Retired)
2010 Ram 6.7 G56 QC CC Aluminum flat/Leveled (Sold)
2008 Nitro Z9 towed by a 2015 Sanibel 3601 towed by a 2013 Ram 3500 SRW CCSB Cummins
2006 EZ GO 6" lift
transamz9 is offline   Reply With Quote
Old 03-01-2014, 08:19 PM   #13
Helmsey's Avatar
Wow! now those are some bright lights. Can you give any details on them or a link to them?
2015 Chevy 3500HD
Old 03-02-2014, 07:09 AM   #14
transamz9's Avatar
The one on the back of the semi are....Blue Water LED
The ones on the boat are....Navigator® Heavy Duty LED Work Lamp 4-1/4 in. x 4-1/4 in. Square Clear Lens, 16 Watt - Tractor Supply Co.
2006 EZ GO 6" lift
Old 03-02-2014, 07:44 AM   #15
Oklahoma Proud
MillerTime's Avatar
Those are awsome!! I need some of those on my tractor and boat.
oops. forgot to check mark that stupid box again!
Old 03-02-2014, 08:46 AM   #16
Canadian Member
itat's Avatar
I put a pair of these 10W LED flood lights on the back of my F150 and they work great.
2X 800LM Cree LED 10W Flood Work Light CAR Boat Truck Driving Square ATV 12V 24V | eBay
They are 800 lumens compared to the 3400 lumens on the back of transamz9's truck, but they're plenty bright enough for my needs. If you need to project to 50' like transamz9 does for his application I'd look into his supplier but that could really irritate your neighbours in a campground at night.
2011 Rockwood Signature Ultra Lite 8293SS, 12K Equal-i-zer WDH
2009 Ford F-150 XLT SuperCrew, 5.4L, 5'6" bed (2012 - 2016)
Old 03-02-2014, 10:05 AM   #17
transamz9's Avatar
Yeah, you don't need the ones like what I have on the truck. LOL! You say 50'? The picture is really a bad example of what those lights do. In a wide open field, they will light 200' up like daylight. You wouldn't be liked very well in the campground.
The ones I have on the boat work great and they are only 500 lumens. I'm sure the one you have work great also.
2006 EZ GO 6" lift
Old 03-04-2014, 11:22 AM   #18
Helmsey's Avatar
I am intrigued by those Cree LED lights, I might need to get one to play with. One of the main reasons I wanted to flush it in the bumper (other than the "different" factor) is that the grill is mounted on the back bumper. They way it is mounted and the way it swings around to use it you would not be able to mount anything to the top of the bumber on the door side of the camper or it would keep the arm from swinging around.
2015 Chevy 3500HD
Old 03-04-2014, 12:32 PM   #19
Canadian Member
itat's Avatar
You could mount them closer to the middle of the bumper (and above the bumper) and just aim them a bit to the outside or you could mount them on the underside at each end. I don't think the stock brackets wouldn't allow you to mount them directly on the vertical surface of the back of the bumper, but if they did they'd stick out about 4", so that's probably not an option.
The spread angle of the light is probably something like 100 degrees. I can take some pictures if you're interested in seeing what they look like.
I was originally looking at Rigid Industries' Dually flood lights when I found the CREE lights on eBay for about 1/3 the cost. The major difference is that the eBay lights don't come with a wiring harness. If money is no object, you could look at these Rigid flush mount backup lights or something similar on eBay.
Rigid Industries LED Lighting | Leader in Off road LED light bars, truck LED lights, Marine LEDs, and Industrial LEDs
Old 03-05-2014, 12:48 PM   #20
Helmsey's Avatar
Man those look nice but they are spendy.
My next Amazon order will have one of the Cree LED's on it to play with
2015 Chevy 3500HD
light, trailer
