Old 10-13-2013, 05:37 PM   #1
BDavis's Avatar
Trailer Leveling
We have a fairly new Windjammer 3006W and love the TT. My only issue is leveling. It has the electric stabilizers, but the unit tends to lean to the left (side with both slides) and even settles a bit on the left after a few days of setup. This even on a level lot. I typically put small leveling blocks under the left wheels to compensate but now wonder if the electric stabilizers are even with it. Thought about adding a removable type scissor jack right in front of the wheels to help level the TT. I saw where Old Coot just added the same electric stabilizers in front of the tandem to limit movement, mine is more of a leveling issue. With that, are the lightweight trailers more prone to "flex" in the frames? Thought?
2016 Sandpiper 365asqb
2013 Rockwood Windjammer 3006W
2014 F250 6.7 PowerStroke 2wd
BDavis is offline   Reply With Quote
Old 10-13-2013, 05:56 PM   #2
Tagged to follow.
2014 Flagstaff 831BHDS
2010 Ram 2500 Cummins 4.10s - Superchip'd
Built-in Controller
Hellwig Sway Bar 7272
Equalizer Hitch system
Long Islander is offline   Reply With Quote
Old 10-13-2013, 06:02 PM   #3
Yes they flex,jacks in front of axle are a (Help)? We pull up on pads on the Slide side. Youroo!!
Old 10-13-2013, 06:05 PM   #4
You bet they help. Thanks again youroo.
Old 10-13-2013, 06:30 PM   #5
OC,we went to (Little Bohemia) to eat and Joyce wore her OC Dollar Ring! Thanks for the Ring! I dont know how Dillenger got out of that place? Youroo!!
ID:	41050   Click image for larger version
ID:	41051   Click image for larger version
Old 10-13-2013, 06:38 PM   #6
Did I not make you a $1 bird?
Old 10-13-2013, 06:40 PM   #7
Fulltime family RVer
I lot of people will "level" with the slide-side being an inch high to account for the expected settling.
ependydad is online now   Reply With Quote
Old 10-13-2013, 06:47 PM   #8
Yes it is Home in my (Treasures) Box! I am also glad you got the (Goshen Gift)! Youroo!!
Old 10-13-2013, 11:02 PM   #9
raspivey's Avatar
So I'm NOT crazy.... I've only had this trailer out once (my first slide out). I'm not a level-nazi, but I get it pretty close. I walked around a few hours later and happened to glance at the level on the front end...about 1/2" low. I wondered how many people leveled a little high on the slide side.
Old 10-14-2013, 08:47 AM   #10
We generally don't do it, but I've read here of people doing it. Remarkably, we haven't been able to feel any settling. But, we also don't have any mounted levels to be able to see it at a glance- though, pretty sensitive to being out of level (as are 2 of our doors- they swing shut when we aren't level). I can usually stand inside and tell you which side is high/low and out of curiosity have proven it with baby bottles on the counter.
