Old 03-24-2014, 03:14 PM   #1
bigdog 616's Avatar
Trailer tire
Help looking to upgrade my trailer tires 26btss it has 6ply grand ride never heard of the tires looking for 8ply 205/75r15 any recommendations looking at Maxxis 8008
bigdog 616 is offline   Reply With Quote
Old 03-24-2014, 03:37 PM   #2
Batts-toy's Avatar
I have the same trailer I went to the Maxxis tires load range 'E'. If you go this route you will need to replace the rims as well the stock rims on the TT are not rated for the pressure.
Dale & Terri, Lulu & Tiki (our Chihuahua's), New rescue puppy Prince - Pom/Pug mix.
2013 Tundra, Double Cab, 5.7, TRD Off-Road, 4X4, Full Tow Package
2013 Wildwood T26TBSS - Sold
2000 Gulf Stream Sun Voyager M-8357 MH, Ford Trident V10 Gasser, 35 foot.
Batts-toy is offline   Reply With Quote
Old 03-24-2014, 05:09 PM   #3
bigdog 616's Avatar
What style rims did you go with and what psi are they and what's the weight rating do have pic. Oh yeah by the way how do you like your trailer any problems
Old 03-24-2014, 05:28 PM   #4
The Maxxis tire is a good tire. Maxxis 225/75R/15D is 8ply 65 psi 2,540lbs: Maxis 225/75R/15E is 10ply 80psi 2,830lbs.
Bob & Sharon, '18 Berkshire 34QS, 2018 Jeep Cherokee.
btritschler1437 is offline   Reply With Quote
Old 03-24-2014, 07:28 PM   #5
Batts-toy's Avatar
I bought Sendel trailer rims Maxis 225/75R/15E is 10ply 80psi 2,830lbs. (copy and pasted from btritschler1437 above) 5 rims and 5 tires from Americas Tire Store a little under $1500.00. I also had them install all steel valve stems another $150.00. Tires and rims were not stock items they ordered them for me.
Old 03-24-2014, 11:12 PM   #6
bigdog 616's Avatar
Send me some pics of the rims and tires on your trailer so what they look like thanks
Old 03-25-2014, 02:47 AM   #7
Batts-toy's Avatar
here is one I have , I will see if I can get a closer shot tomorrow.
Old 03-25-2014, 07:39 AM   #8
bigdog 616's Avatar
Looks like you went with aluminum wheels look good
Old 03-25-2014, 11:28 AM   #9
Batts-toy's Avatar
Thanks, here is the close-up I promised. The center of the cap is removable for greasing without taking the wheel off the TT.
Name:	New Maxxum Tires and rims.jpg
Old 03-25-2014, 12:46 PM   #10
Maxxis 8008 LR D were what I used when I had the old trailer. I towed it ~3500 miles before we sold it to get this one. The tires worked very well, and I did not have to change the rims. At LR D,the tires had about 800 lbs of extra capacity over the GVWR of the trailer. The LR C that were on there were well under the GVWR due to the FR assuming a tongue weight on 10%.
ST Williamson
Current TV:'14 F350 Lariat CrewCab, 4x4 Short Bed SRW Diesel w/ Pullrite 2700 (16K)
Current
Fiver: '15 Puma 295BHSS Anniversary Edition
Past TV: '13 F150 HD Payload SCrew EB, '08 Tundra CrewMax 5.7L, '02 'Burb 5.3L, '97 Dakota 3.9L
Past Trailers: '09 Wildwood LE 27RB, '02 Palomino Yearling RL, '87 Jayco 1006dlx
campingwilliamsons is offline   Reply With Quote
tire, trailer
