Old 02-21-2013, 01:40 PM   #11
FreedomTracker's Avatar
We only use 1 battery, so I purchased an additional battery box from WM ($8.00?) to sit next to it. I simply use the add'l box for cheap tools and flashlight that come in handy for hitching up etc when I'm outside. Much easier than having to unlock main storage compartment or looking inside trailer.
Since it simply looks like another battery, not worried about theft....
2012 Ford F150 4x4, 5.0L, 3.55
2011 Rockwood MiniLite 1809s
E2 WDH 600/6000lbs
FreedomTracker is offline   Reply With Quote
Old 02-21-2013, 02:01 PM   #12
Jeffco, MO
tedstr's Avatar
My Storage Box
Enough room for two batteries and small tool box and chocks. Bolted box to the frame. Never had trouble with sharp turns. Lowest priced tool box at Lowes. Used on my travel trailer that I traded in for my Wildcat.
Mary & Ted
2016 Silverback 33IK
2015 GMC Sierra 2500HD CrewCab Diesel/Super Glide Hitch
Days camped 09 -53, 10 -56, 11 -57, 12 - 55, 13 - 46, 14 - 50, 15 - 60, 16 -32
7 FROG Rallies (Goshen(4), Charleston, Amana(2))
tedstr is offline   Reply With Quote
Old 02-21-2013, 02:48 PM   #13
grege's Avatar
So the squared off corners didn't give you any problems on your turning? Did you vent it? Any chance you remember the measurements of it?
'12 Ford F150 Lariat Super Crew
'17 Grand Design Imagine 2800BH (Previous '13 Roo 21SS)
2016 Nights camped: 7
2015 Nights camped: 21
2014 Nights camped: 18
2013 Nights camped: 26
grege is offline   Reply With Quote
Old 02-21-2013, 03:17 PM   #14
Fire Instructor's Avatar
I did similar to Tedstr, with a narrow box from Lowes. Vented the back of it by drilling holes, then covering the holes with fine screen. I have hit it once with the corner of my bumper, making a VERY tight backing in move (almost a jack-knife). Mine holds two 6v GC batteries (soon to be four batteries), lynx-levelers, assorted wood blocks, and a few other odds and ends typically used for leveling/stabilizing.
Fire Instructor
2014 RAM 2500 Laramie 4x4 Quad Cab w/Cummins Turbo Diesel, 2009 Rockwood 2607, and 3 'yaks!
300W of Suntech Solar, a Rogue MPT-3024 Controller, and a Xantrex PW2000 Inverter
Fire Instructor is offline   Reply With Quote
Old 02-21-2013, 03:20 PM   #15
I put on a similar box made of heavy duty plastic. It is a snug fit between the propane tanks and the front of the trailer similar to tedstr's picture above. I built a wood platform that I U bolted to the trailer tongue and then bolted the box to the wood platform. I did put the battery in the box and therefore vented it. I cut holes in the back and then attached several pvc elbows (facing down) to both vent the box and also to run the battery cables. No issues with water getting in or any built up fumes. It works well and I basically just use it store wood blocks and my weight distrution/sway equipment. I think it was about $40 at Lowes and is lockable. The picture below is not very good but you can see the box sitting behind the propane tanks.
2011 Surveyor SP260
2012 Ford Expedition
chof16 is offline   Reply With Quote
Old 02-21-2013, 04:35 PM   #16
Jeffco, MO
tedstr's Avatar
Storage Box
I did the same as Fire_Instructor. Vented holes in the back (side toward trailer) to keep out the rain. As far as turning, I drew a string from the hitch ball to the corner of the trailer and the box stayed inside of the string, so I never had any turning problems. Measure with a string in place and get the max dimension for the box you buy. I think my box was for a medium truck, not a full size. The advantage of the box was that you could lock it if you kept your personal tool box inside.
Mary & Ted
Old 02-21-2013, 05:09 PM   #17
grege's Avatar
I think another advantage is that the battery would fit better all the way to one side. Love to be able to lock it and keep the WDH bars and hitch in there maybe. Those tongue boxes would make you put it more towards the middle.
Old 02-21-2013, 05:34 PM   #18
itch'n to road trip
campnqueen's Avatar
Send a message via AIM to campnqueen Send a message via MSN to campnqueen Send a message via Yahoo to campnqueen
WARNING! Be very careful what to mount to your trailer tongue. Think about what you are going to carry in that box. Look to see what you TV hitch max tongue weight is.
2012 Ford F-250 King Ranch Super Crew Cab 4x4 "Mae West"
2014 Work & Play 25ULA "Ula"
Paula Drake, Ken Cooksey, Sunny Delight & Valor
Jasper Ga.
campnqueen is offline   Reply With Quote
