Old 02-26-2010, 02:44 PM   #1
NWJeeper's Avatar
Trimetric 2025 Battery Monitor
I just finished up the installation of the Trimetric 2025 battery monitoring system in our Georgetown. As we like to dry camp I wanted to have a better idea of what our system is doing in terms of power usage and solar charging.
Installation was fairly easy and took me about a day when all was said and done. The meter is the one on the right in the picture (sorry it's a bit out of focus causing the display to appear to be "on fire") The reading is set on amps and is showing a charge of about 3 amps. If you are drawing more than you are putting into your batteries then a negative symbol will light up on the left side of the display. The unit will display voltage as well and when programmed with the total amperage capacity of the battery bank will also show percentage of battery power (in amps) since last fully charged. The meter is installed so that it will track all power into the batteries (from the engine alternator, onboard charger or solar panels) and power being used from the bank.
Once installed I confirmed it was set up correctly and started to take some readings. The cool thing is that when you turn something on you can see immediately how much power it is using. Here is what I found when I started using the meter:
At rest, no shore power and batteries disconnected there was about .1 amp draw (probably the meter itself).
LPG detector draws .2 amps
Single dual bulb light (198 bulbs) 2.3 amps
Single dual bulb light (LED panels) .1 amps
Light fixture over dining table (4 198 bulbs) 4.5 amps
Single reading light over bed (1 198 bulb) .8 amps
Recessed Halogen lighting, living room (6 lights) 8.4 amps Full on
2.1 amps Fully dimmed
Recessed Halogen lighting, over sink (1 light) 1.4 amps Full on
.4 amps Fully dimmed
Recessed Halogen lighting, over couch (3 lights) 4 amps Full on
1.2 amps Fully Dimmed
Refrigerator 1.2 amps
Furnace (Suburban SF35) 7 amps
Water Pump (Shurflo Smart Sensor 5.7) 11.9 amps running, 12.6 max
Exterior porch lights (3 incandescent bulbs) 2.8 amps
Exterior Porch Lights (3 LED bulbs) .8 amps
Of considerable interest to me was the amount of amperage the water pump draws. I had no idea it drew so many amps.
Some things to consider about power usage and battery banks you can draw from this information:
If you have an RV equipped with a single group 27 battery (many trailers) you have about 105 amp hours of capacity on the high side. If you dry camp and run NOTHING but the refrigerator then in 1 day you will use 28.8 amps of power, almost a third of your capacity! That's not including running the pump, furnace at night to stay warm or a few lights for a few hours in the evening. You can see fairly easily from this that if you are dry camping where it will get cold at night you very easily can wake up the next morning with a dead battery.
My testing continues as does my learning on how to extend our dry camping capability using our solar panels.
I am still awaiting the arrival of several different LED bulbs for testing and will report my findings on them in another post.
Ed & Wendy
www.nwjeepn.com
Old 02-26-2010, 02:58 PM   #2
MtnGuy's Avatar
Very interesting, NWJeeper. I had no idea that 2 12 volt bulbs would pull that many amps. 3 fixtures on equals the furnace fan.
Why does the fridge draw amps in the propane mode?? Would your defrost strip be on ??
Old 02-26-2010, 03:09 PM   #3
NWJeeper's Avatar
The electronic circuit board I would guess is part of what is drawing the amps on the fridge. I have not checked the defrost strip. Our fridge also has fans that come on, I suppose to move more air over the cooling fins on the back side but they were not running at the time.
When you start to put things in perspective like you pointed out with the lights it really does open your eyes as to how fast you can use up your battery power.
Ed & Wendy
www.nwjeepn.com
Old 02-26-2010, 03:17 PM   #4
MtnGuy's Avatar
Now you got me wondering about my fridge on propane.
I know that the fridge in a motor home is probably different than in a travel trailer, but 1.2 amps seems high for a circuit board.
I might have to get me 1 of them puppies to see where all of my battery juice goes.
Thanks for all of the excellent info.
Old 02-26-2010, 03:43 PM   #5
NWJeeper's Avatar
I went out and looked all over for a switch for a defrost strip on our fridge but there seems to be none. I know it does build up frost on the inside and I have to turn it off every few months to defrost it. I don't think ours has one or if it does you can't turn it off.
Ed & Wendy
www.nwjeepn.com
Old 02-26-2010, 03:51 PM   #6
MtnGuy's Avatar
on our Dometic Model #DM2652, the toggle switch is on the upper freezer door opening.....you have to open the freezer door to get to the switch.
Old 02-26-2010, 06:41 PM   #7
NWJeeper's Avatar
Yep, only thing there on our is 3 switches for, on/off, Manual/auto and Temp set. There are no other switches on our fridge. I opend all the doors looked all around the frame and in the back of the fridge and could find nothing.
Ed & Wendy
www.nwjeepn.com
Old 04-07-2010, 01:35 PM   #8
rsl
I just oredered my 2025-rv today and the 500 amp shunt. Any tips, tricks, suggestions to pass on from your install experince?
2010 Cherokee 295U 36 foot 5th Wheel.
rsl is offline   Reply With Quote
Old 04-07-2010, 02:25 PM   #9
baldy's Avatar
I have a question. What does the electronics of the Trimetric 2025 draw? I would assume that the amp draw from this would have to be factored into the overall equation? My fridge has an LED on it to indicate that it is operating. Just a whisper in the grand scheme of things but it would add up over time.
baldy is offline   Reply With Quote
Old 04-08-2010, 06:25 AM   #10
Herk7769's Avatar
My unit is sitting on my workbench. Will photo my progress and post them. Hope this goes as well as I hope. Planning a complete DC system mod with dual batteries and selector switch monitored by the Trimetric 2025RV.
HAM CALLSIGN - KC3FFW
battery
