Old 10-20-2015, 04:35 PM   #41
Left Coast
Fed x on the way.
Old 10-21-2015, 04:38 PM   #42
TURBS's Avatar
50 amp hardwired ems and 55amp boondocker converter showed up today.
TURBS
2008 duramax
2015 columbus 320RS
2015 camping "31 nights"
Old 10-21-2015, 04:59 PM   #43
Kenny kustom's Avatar
Open that boondocker box.
What made you pick that, over some of the others?
2008 F350 CCSB V10
2016 Sabre 36QBOK
2017 Dynamax Isata 4
Old 10-21-2015, 07:22 PM   #44
TURBS's Avatar
I bought the boondocker to replace the junk wfco converter right from the start.
Turns out the they spec'd a wfco but installed a proggresive dynamics instead.
TURBS
2008 duramax
2015 columbus 320RS
Old 10-21-2015, 07:26 PM   #45
TURBS's Avatar
Installed the 50 amp progressive industries hardwired ems in one hour and ten minutes.
start to finish.
ID:	92449Click image for larger version
ID:	92450Click image for larger version
TURBS
2008 duramax
2015 columbus 320RS
Old 10-21-2015, 08:06 PM   #46
CAT-RN's Avatar
Mods are looking great!! One thing to consider. Each mod is adding a bit of weight. My thought is you are already stretching the limit on that Bow Tie with out any extra weight!!
Russell.
CAT-RN is offline   Reply With Quote
Old 10-21-2015, 08:07 PM   #47
TURBS's Avatar
That bow tie would pull the cab n box clear off that ford
TURBS
2008 duramax
2015 columbus 320RS
Old 10-21-2015, 08:13 PM   #48
Left Coast
Russell.
Bigger chip ordered....
Old 10-21-2015, 08:17 PM   #49
TURBS
Just throw a chain thru one rust hole and out another and you could tear it in two pcs or just cut it loose from whatever is left of the rusting frame.
Old 10-21-2015, 08:27 PM   #50
Left Coast
Just him a 'break-down'tool........ red,yellow, and green flare set with hand-held launcher...he'll have to supply the welding glove to use!
320rs, columbus, modifications
