Old 07-28-2016, 02:09 PM   #11
X2
Blest with a Coachmen Prism 24G
I Simpson is offline   Reply With Quote
Old 07-28-2016, 02:09 PM   #12
JustB_Rad's Avatar
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
2016 Grey Wolf 26DBH following a 2014 RAM 1500 Outdoorsman
Life is good...Live it!
(2014) Nights Camped - 16 in 6 trips (2015) Nights Camped - 20 in 6 trips
(2016) Nights Camped - 21 in 7 trips
Winter :'(
JustB_Rad is offline   Reply With Quote
Old 07-28-2016, 02:10 PM   #13
Originally Posted by tom48 View Post
for your 110 the outside box should be a male and that way you just plug in a normal outdoor extension cord into it without any exposed hot prongs.
For the cable unless you are creating a new location for a tv you should already have cable to the tv connection points. But the method is fine. That is what i did to bring in the cable lead from my direct tv portable antenna. Just work real carefully when you're cutting into the wall and remember dicor, putty tape, and as a finish, clear silicone.
definitely!
Old 07-28-2016, 02:28 PM   #14
Originally Posted by BandJCarm View Post
Two things I can think of that I'd really like to have..........and odd that it isn't done this way, but....
2) On same vein, with all the hubbub about trailer coax wiring and tv's, and what goes where.......it would seem to me to do the same thing as #1 above but just put two female F connector plates on each side of the wall. Put it beside the area where tv is. Connect the two via short coax.
Both require drilling holes in camper. Unlikely DW will agree, but still I'd like to know your opinions of the feasibility of either/both.
Thanks.
I did the exact same thing you are talking about and it has worked fine for four years. As someone else said they must be offset due to wall thickness. Winegard has an outside fixture that is inexpensive and has a cover.
VMI'62
Edmund is offline   Reply With Quote
Old 07-28-2016, 02:53 PM   #15
BandJCarm's Avatar
Thanks, guys.
No, not looking to have a power cord with two male ends. "Inlet"......a word I didn't know (DUH!!)......yeah, that.
Jaybird (I think) has it. Just some way to get an extension cord 'neatly' into the trailer and terminate on a plug.
Coax is same way. I THINK I am going to be able to figure out the trailer wiring, but in the past I've had to go through a window with a short piece of flat coax, and this would alleviate that problem.....plus it seems like it should be the way trailers are wired for tv.....if they have just one tv......
Thanks again.
"Next to prayer, fishing is the most personal relationship of man"Calvin Coolidge
FROG AR-0019-242
BandJCarm is online now   Reply With Quote
Old 07-28-2016, 03:04 PM   #16
Installed one of these! Youroo!!
Old 07-28-2016, 03:24 PM   #17
AKA: 'tiredTeacher
awellis3's Avatar
Two things I can think of that I'd really like to have..........and odd that it isn't done this way, but....it would make sense to me to make a regular dual outlet inside the trailer.........and another (waterproof) one outside on the opposite side of same wall......and wire the two together......so that all I'd have to is plug the extension cord to the power pedestal, and then to the outside plug. Then go inside and plug to the inside plug.
West Marine sells a water-resistant receptacle. You drill a hole in the trailer and mount it. The outside has a 110V male to plug an extension cord into. I hardwired an extension cord to the fitting on the inside. We use it to power an electric heater in the living room.
Here it is in the catalog: MARINCO 15A Battery Charger Inlet | West Marine
Here is my install -
Wright and Penny
(with Fitz and Lizzie, the camping kitties)
Richmond, Va.
2010 Tundra 4X4 5.7L V8
2014 Rockwood 2604WS
Life is a cruel teacher. She gives the test first; the lesson then follows.
awellis3 is offline   Reply With Quote
Old 07-28-2016, 07:10 PM   #18
cable connector
Installed one of these cable connectors (bought from Furrion) to connect my portable direct tv dish to my receiver.
ID:	115658   Click image for larger version
markb422 is offline   Reply With Quote
Old 07-28-2016, 07:38 PM   #19
keeprr's Avatar
Lucky me! I have two receptacles, one in the door side rear trunk wall of the 5er with a cutout thru the floor and another in a compartment on the drivers side with a cutout in the bottom of the compartment. Really conveniemt.
2016 Open Range Light 297RLS Fifth Wheel
2015 GMC 2500HD 6.6L Duramax
Days Camped. 2015: 17
Days Camped 2016: 58
keeprr is offline   Reply With Quote
Old 07-29-2016, 09:41 AM   #20
wmtire's Avatar
The site team has done a cleanup in this thread, of posts that were off-topic to what the OP has stated he is doing in post #15.
Please keep this thread on track...and most of all, post responsibly.
Thank You
2011 Flagstaff 831 RLBSS
Hypochondria is the only illness I don't have.
cat, modifications
