Originally Posted by DDC
Looks beautiful, but I have to ask why two?
DDC You would have to ask............
The bottom one I made and installed, then I found that it was set too low at 29". So............. to keep from leaving holes in the wall and I had the material to make a second one ---- back to the shop. The top one is set at 35". 34" to 38" is hand rail code. I should have looked up the code before installing the first one. What do you think, does it look OK????
