Old 05-10-2014, 02:58 PM   #1
realebill's Avatar
update on LED strip install....
purchased the new LED strips and made sure i got the weatherproof strip. installed the wiring,and put the controller in a weatherproof box. thought that was enough. sadly,i didn't account for water tracing the connection which meant that it followed the wire thru the notch in the weatherproof box and...into into the controller. this weekend we tried to turn on the light strip,nothing....after examining all the components,i took apart the controller....toasted ! luckily,i can get a replacement for about $4.
now,to reconfigure my installation so water will stay out.
2008 rockwood signature ultra lite 8315SS[SIGPIC]
realebill is offline   Reply With Quote
Old 05-11-2014, 06:17 PM   #2
Jimmerinwi's Avatar
That sucks. I would try to keep the box above the strip a bit if possible, that water is less likely to run uphill.
Some days I wake "Grumpy", Some days I just let her sleep......(Ray Scott)
Jimmerinwi is offline   Reply With Quote
Old 05-11-2014, 08:34 PM   #3
I install the led lights also on my rockwood 8289ws
what I did was put the control box inside the trailer un solder the wire
used bell phone wire 6 ft to the led strip and 1 ft to the eye out side
(ps make sure you put the wire's on the right spot )
Manfred
2018 Dodge 1500 4x4 5.7 HEMI
2013 Rockwood Ultra Light 8289WS
Night's Camped 2014 ( 37 ) 2015 ( 28 ) 2016 (46)
2017 ( 51 ) 2018 (5)
Merrickville Ontario
Manfred & Denise
freddy2 is offline   Reply With Quote
led
