Old 12-01-2013, 03:28 PM   #1
Updated from Manual Tongue Lift to Powered!
My 11 year old and I replaced the Tongue Lift today. Nice and easy job especially since the only other job we've done is install combination bin locks...
We lifted the rv up on 4x4's, unscrewed the three bolts on the top side of the frame, and pulled out the manual lift. The we just inserted the new one, used the same bolts, and tightened it down.
The red fuse circular cable confused us, but we read that we had to cut it and then attach it to the end of the positive cable. It's odd that they just don't put it on the end of the cable. Also, there was no negative cable included as it expects to be connected to a frame that is connected to the negative side of the battery. It didn't work until we connected a wire to the battery.
We went to auto zone and bought some 10 gauge cable for the negative wire, crimping cable connectors, two loop crimping connectors to go on the battery, and two smaller loop crimping connectors to go on the lift as the negative cable.
We wired it up and it works!
I bought this powered lift.
In the second picture, my son had the smart idea to use the small loop on an existing screw. I was going to drill a hole and set a screw... He saved us a bunch of time.
HalGumbert is offline   Reply With Quote
Old 12-01-2013, 03:37 PM   #2
Camper Less Camping
Cajun Po-Boy's Avatar
Must do mod on TT's...great job
2013 Sabre 32RCTS-6 (sold)
Cajun Po-Boy is offline   Reply With Quote
Old 12-01-2013, 03:39 PM   #3
Good job,you now have (2) grounds. The Jacks ground from the frame when you clean the bolt area down to bare metal. Youroo!!
Old 12-01-2013, 04:14 PM   #4
Ford Idaho's Avatar
The family that camps together mods together.
Be sure and cover the jack with a 5 gallon bucket or something.
Ford Idaho is online now   Reply With Quote
Old 12-01-2013, 07:40 PM   #5
raspivey's Avatar
I did the same to my popup when I screwed up and bent the original jack. Best move I'd made. If my new one hadn't come with one, it would have gotten it shortly. Hindsight and might have been easier just to back up to it and drop it on the ball to swap them instead of putting it on boards. Was for me anyway.
2012 Chevy Tahoe LTZ - HD tow package
Old 12-05-2013, 08:31 PM   #6
mark0224's Avatar
Invented my own all in all it cost me less than a dollar to make because I had most of the parts. Used it on my old trailer and moved it to my new one takes all of 10 min to do. I love it saves so much time setting up.
mark0224 is offline   Reply With Quote
manual, power
