Old 05-27-2015, 11:11 AM   #1
Bianchina3's Avatar
Upgrade/repair water level guages
I have a 2011 Puma 26RLSS. When we went camping this weekend we were going to be out for three days. We have a 51 gallon fresh water tank. The fresh water gauge showed full the whole time but I knew it didn't work correctly (it shows full when I know it's empty). The grey water tank was erratic and black showed was empty the whole time. I could care less about the grey and black (for now).
My DW was obsessed with the fresh water level. She was afraid we would run out. She asked if I could fix the fresh gauge, which I replied "Pssshhh, Of course, I can fix anything!" When we got back home and I looked under the camper the tanks look as if they are in big heavy plastic enclosures. It also looks like the tank sits on top of a metal beam and goes the full width of the frame. I think access will be a problem.
I was looking at replacing it with something like SeeLevel gauges that attach to the side of the tank but I don't know if I can get to the side of the tank.
Any insight is more then welcome.
Ed,Jennifer, Dixie and Beau Bianchina
2014 Dodge Ram 1500 Crew Cab
2011 Puma 2011 26 RLSS
Days camping in 2017: 25
Bianchina3 is offline   Reply With Quote
Old 05-27-2015, 11:24 AM   #2
It sounds like your gauge may be wired wrong. I have never had a problem with my fresh water gauge, black and gray yes because of buildup on the inside walls. I would double check the wiring on the back of the control board first before I buy a new system. I think FR tried the sensors that go on the outside of the tank and found they did not work that well.
Ontario
Vibe 6501
1 Prospector Canoe
2 Mtn. Bikes
4 Hiking Boots
Happy Vibe is offline   Reply With Quote
Old 05-27-2015, 11:26 AM   #3
Oaklevel's Avatar
Just my two cents..... Most of the RV tank gauges are problematic and not worth the time and expense involved ...... The only only one I might repair is the fresh water tank.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Sadie & Lillie Spoiled Rotten Boxers
Old 05-27-2015, 11:50 AM   #4
Bianchina3's Avatar
Here is something strange we noticed. When we go home and the fresh tank was empty it read empty. I needed to put some water in the tank to run the pump and it read empty for a while and then switched to FULL all at once. Maybe there is a problem with the wiring.
If I didn't fix the system are there other ways to check the tank level then?
Old 05-27-2015, 03:04 PM   #5
The only way is with the meter or to crawl under and look at the tank. I still think your wires are not connected right. There are 4 sensor in the tank. one common sensor and a sensor for 1/3, 2/3 and full. If any of theses are on the wrong sensor it will give you some strange readings.
Ontario
Vibe 6501
1 Prospector Canoe
2 Mtn. Bikes
4 Hiking Boots
Old 05-27-2015, 03:09 PM   #6
Oaklevel's Avatar
After awhile you kind of know but most of the time you can look into the toilet for the black tank level....... Gauges haven't been around forever our first two campers did not have them........ If the grey tank is full it will come up in the shower, galley tank the sink I know then its a little late by then....... but we can go over a weekend, Usually 5 days without emptying but everyone's tanks are different size & water consumption is different.
I rarely pay any attention to them.
1966 Mustang GT
1986 Mustang SVO
Old 05-27-2015, 03:20 PM   #7
Herk7769's Avatar
This system is VERY easy to troubleshoot provided you have access to the tank probes (outside of tank).
Inside of tank problems are more often than not the result of poor tank maintenance and winterization techniques. The OEM probes are just buttons but they are close to the tank walls and sludge can easily bridge the button to tank wall resulting in a bad reading. Low resistance (like a short) makes the tank read full; high resistance (like an open) makes the tank read empty.
ANY probe shorting to the tank wall will make the tank read full.
Here is the troubleshooting guide for the "outside of tank" issues.
ID:	78243   Click image for larger version
Name:	Horst Probe Install 044.jpg
File Type: pdf KIB Monitor Panel M21 Wireing Diagram.pdf (51.2 KB, 52 views)
File Type: pdf Micro Monitor Panel Troubleshooting.pdf (149.2 KB, 60 views)
HAM CALLSIGN - KC3FFW
Old 05-27-2015, 03:29 PM   #8
DAISY BOYKIN's Avatar
Having trouble with tank readings.
I too had trouble with tank readings. I removed the "Idiotic BOARD" on the wall, found the nylon nuts that held the diode board in place was loose ("the ones that give you the level readings") I simply tighten the nylon nuts and all works well now!
Hope you solve your problem?
Sid, Lois & HRH MISSY Terrible 2s SHIH TZU
2011 ROCKWOOD 8285 WS
2014 F-250 KING RANCH PS/SD/6R140/BFT
DAYS CAMPED 2018 21 DAYS
DAISY BOYKIN is offline   Reply With Quote
Old 05-27-2015, 06:32 PM   #9
Bianchina3's Avatar
You guys are awesome! Thanks.
A few things I found funny:
Oaklevel doesn't use the level gauges.
I'm a quality manager for an electronics manufacturer and I always tell the engineers that if you have to have a trouble shooting guide you didn't design it right in the first place!
repair, upgrade, water
