Old 06-16-2018, 08:54 PM   #11
Another step option
Forest River offered a two step option of MORryde steps on some Salem Cruise Lite trailers. I read that they were only available to OEMs but I found them at Camping World. The link is below.
For those that are unfamiliar with these MORryde steps they fold inside your door. There are two extendable feet that allow for uneven ground.
I still haven't replaced my single step stairs. I'm torn between just going cheap and moving the under carriage supports to 25.5 inch separation and getting regular two step stairs. The very nice Torklift stairs would require me to move the supports anyway.
https://www.campingworld.com/stepabo...-26-to-28-door
michaelcerda is online now   Reply With Quote
Old 06-19-2018, 05:55 PM   #12
jakropp's Avatar
Here are a few pics of the steps. Sorry for the bad lighting, the sun was on a funny angle and my phone was having trouble with it. Also, disregard the height to the ground from the bottom step. My TT is leveled on a side to side grade so the step side of the trailer is pretty close to the ground when folded out. On flat ground they split the height of the trailer perfectly.
You can see the third bolt I added to suck in the side plate on the TT. Because the steps are a hair wider than the plates it wedges them apart so using only the top 2 bolts on each side left the side plates sticking out slightly on an angle. I am sure it is not an issue but I didn't like the look of it so I added the 3rd bolt to pull them in. I used an existing hole on the side plates and drilled through the stair unit. Then an SS bolt and locknut and off you go.
Hope this helps some of you that are on the fence and thinking about it.
2017 Salem CruiseLite FSX 197BH
2017 Toyota Sienna SE
jakropp is offline   Reply With Quote
Old 06-19-2018, 11:01 PM   #13
Steps installed
ID:	176595   Click image for larger version
TV: 2017 GMC Sierra CrewCab 4x4 5.3
TT: 2018 Forest River Salem Cruise Lite 201BHXL
Bikemobile is offline   Reply With Quote
Old 07-15-2018, 05:56 PM   #14
We just installed our MORryde steps and love them. I shopped around on line and found them for less than camping world. Installation was a breeze. Rock solid and they donít shake the camper as much when someone is entering and exiting.
Iíd put in a picture but I donít know how
Judemaster is offline   Reply With Quote
Old 07-15-2018, 06:34 PM   #15
Mr. Dan's Avatar
See my answer to your question in your "How do I post pics?" thread.
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 =111/'19 = 0; booked = 14
lite, salem
