Old 02-09-2016, 07:52 PM   #11
Justice12t's Avatar
Purchased black for my Crusader...They just arrived but unsure when I can install them...they are calling for single digit temps here this weekend...
2016 Prime Time Crusader 294RLT
2016 Days Camped - 31
2017 Camping Blues - ...
Justice12t is offline   Reply With Quote
Old 02-09-2016, 08:58 PM   #12
TURBS's Avatar
Originally Posted by mach8274 View Post
Black on ours as all the trim on the trailer is black. They are made by Camco and they are NOT translucent. They are a solid black with no light whatsoever coming through them.
Mine are black to "not" smoke.
Light does not come through.
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
Old 02-09-2016, 10:08 PM   #13
since your post is a direct reply to mine I will answer in this way.....I suppose I should have said...."all the vent covers I HAVE DEALT WITH were translucent no matter the color".....I've installed three, two whites and one black, ....all were Camco brand and all were translucent, not a true sun block until I had sprayed several coats of black paint to the inside surface,........that's a trick I learned to make my truck's "Auto Ventshades" a true sun blocker and not just a sun shade..... it was very annoying to have the afternoon sun to shine thru my Auto Ventshades as I would drive home from work, .....I found that after a good coat of paint to the under side I had a true sun blocker, not just a translucent sun shade........and it worked the same with the three trailer vent covers that I've installed......
fella10 is offline   Reply With Quote
Old 02-09-2016, 11:12 PM   #14
asquared's Avatar
On our old tt we had the max air II vents. We had a white one over the bathroom and a smoke one over the bedroom. The white one was cheaper. The smoke one let in a little less light and we could see out the vent over the bed better. We let them go with the old tt. The fiver has a black one over the bathroom vent because that was the color they had. I like the black one the least but it doesn't really matter. Get the one that matches your trailer the best. Here is a pic of my old tt. The front grey hump is the smoke cover. You can see the rear white one easier from the single the pic was taken.
<a href=http://i62.tinypic.com/28rp645.jpg target=_blank>http://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
Old 02-09-2016, 11:43 PM   #15
Phat Phrog Stunt Crew
elind's Avatar
2015 Columbus 320RS
2008 2500HD Duramax
Sounds like you want it dark in the playroom!!
2014 Wildcat 327ck
elind is online now   Reply With Quote
Old 02-10-2016, 06:00 AM   #16
TURBS's Avatar
Sounds about right!
2015 Columbus 320RS
2008 2500HD Duramax
Old 02-10-2016, 06:23 AM   #17
Originally Posted by dcheatwood View Post
Had black originals, but they dry rotted and fell apart in 3rd year. Just replaced with thick white ones..
MaxAir covers have 6 year Warranty,but I have seen RV's parked way longer than that with MaxAir covers that still looked New,they were all white though! Youroo!!
Old 02-10-2016, 06:31 AM   #18
AquaMan's Avatar
I had white ones on our Sierra along with the vent pillows with the reflective foil on one side. Did a great job keeping heat and cold out. I also installed the Vent Stik knobs on the vents, as most were taller than I could reach. The Stik helped with installing and pulling the pillows out also.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
Old 02-10-2016, 04:28 PM   #19
2015 Columbus 320RS
2008 2500HD Duramax
Very nice
5ERSTEVE is offline   Reply With Quote
Old 02-10-2016, 04:30 PM   #20
I Break Everything
mikel68's Avatar
Black for us, Our MH is black, plus less heat through them. Texas gets hot.
2015 Georgetown Forest River 351DS MH
2008 Keystone Cougar 293SAB 5th Wheel
2007 Jay Flight 30.5RLS 5th Wheel
2006 Jay Flight 29BHS TT
mikel68 is offline   Reply With Quote
black, cover, vent
