Old 02-02-2016, 01:51 AM   #1
Vent covers white black or smoke?
Other than the way they look from the outside are there pros and cons to different colors? Opinions?
5ERSTEVE is offline   Reply With Quote
Old 02-02-2016, 02:04 AM   #2
Who Dares, Wins
doc73's Avatar
White will let the most light in, black the least... Smoke in the middle. I find that a LOT of heat and cold comes through my vents and have blocked them off with reflextix insulation (I have white vents). If I had a do over I;d do black just to keep out the heat. I do not need the light, that is what LEDs were made for. BUT, the black will get hotter... So all my thought might be for not, welcome BTW.
2015 Chevy HD D-Max
2022 Impression 315MB
doc73 is offline   Reply With Quote
Old 02-02-2016, 06:36 AM   #3
Just pick a color,we chose white! We also chose MaxAirII covers for all our Vents,power and Non power! MaxAir Fan Mates are also a New Option for Power or Non power vents! I see you have a PT Crusader,Rockwood/Flagstaff now install MaxAir covers at the Factory,The vent LIDs are very thin and their Life span is Very short,cover them all! Also Highly recommend Inside vent cushions for (1 noise reduction,2 repel Summer Heat entering,3 Prevent Heat Loss in Cold conditions,4 block Bright Sunlight! Youroo!!
Old 02-02-2016, 07:33 AM   #4
jeff64's Avatar
Had white on the old TT, because TT was white. This one(emerald edition) came with black Max Air IIs on 2 out of the 3 and installed smoke Max Air II on the 1 that I did buy extra, just for looks. It lets in a surprising amount of light (as if it were clear). From looking at it from the ground, you can't really tell that they aren't all black. What looks good to you?
2016 Flagstaff 27VRL Emerald
14K Equalizer
2020 Silverado 2500HD CC 4X4 6.6L gas 3.73
Old 02-02-2016, 07:45 AM   #5
TURBS's Avatar
Black! I like it dark when I sleep in!
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
Old 02-02-2016, 07:48 AM   #6
Jeff I see yours is a 16,all the 16's on display at Goshen had Max Air Fan Mates installed from the Factory? This was on the Rockwood/Flagstaff units! Youroo!!
Name:	DSCF4598 - Copy.jpg
ID:	98777   Click image for larger version
Name:	DSCF4599 - Copy.jpg
Old 02-02-2016, 02:24 PM   #7
heavynlori's Avatar
We have smoke covers on our Crusader
We also have those vent pillows to put in each one - kitchen one is never used, pillow in place 24/7 (cannot reach vent anyway)
heavynlori is offline   Reply With Quote
Old 02-03-2016, 10:40 PM   #8
all the vent covers are translucent no matter the color,
they don't block the sun, they just defuse it and we didn't like that,
on three different vent cover installs, before installing I've always taped off and protected the top side of the vent cover, and then sprayed the underside w/several coats of flat black paint to create a true sun block,
on the two white covers, I then applied a coat of white over the black and they both looked just like they did originally, except then they were a true sun block cover,
blocking both sun and heat,
if I ever install another vent cover, I'll repeat the process every time, we like the results
fella10 is offline   Reply With Quote
Old 02-09-2016, 08:26 PM   #9
mach8274's Avatar
Black on ours as all the trim on the trailer is black. They are made by Camco and they are NOT translucent. They are a solid black with no light whatsoever coming through them.
Dave & Amy
5 kids, 2 with 2 legs, 3 with 4 legs
2016 Columbus 385BH
2016 F350 6.7L PSD CC Lariat DRW
Ford factory puck system with 26.5k hitch
mach8274 is offline   Reply With Quote
Old 02-09-2016, 08:48 PM   #10
dcheatwood's Avatar
Had black originals, but they dry rotted and fell apart in 3rd year. Just replaced with thick white ones..
2018 Forester 3011 DS
Old 02-09-2016, 08:52 PM   #11
Justice12t's Avatar
Purchased black for my Crusader...They just arrived but unsure when I can install them...they are calling for single digit temps here this weekend...
2016 Prime Time Crusader 294RLT
2021 RAM 3500 Laramie Mega HO\CTD, CC, 4x4...ect
Days Camped in last 3 years - 79
Planned Days in 2021 - 50
Days Camped in 2021 - 0
Justice12t is offline   Reply With Quote
Old 02-09-2016, 09:58 PM   #12
TURBS's Avatar
Mine are black to "not" smoke.
Light does not come through.
2015 Columbus 320RS
2008 2500HD Duramax
Old 02-09-2016, 11:08 PM   #13
since your post is a direct reply to mine I will answer in this way.....I suppose I should have said...."all the vent covers I HAVE DEALT WITH were translucent no matter the color".....I've installed three, two whites and one black, ....all were Camco brand and all were translucent, not a true sun block until I had sprayed several coats of black paint to the inside surface,........that's a trick I learned to make my truck's "Auto Ventshades" a true sun blocker and not just a sun shade..... it was very annoying to have the afternoon sun to shine thru my Auto Ventshades as I would drive home from work, .....I found that after a good coat of paint to the under side I had a true sun blocker, not just a translucent sun shade........and it worked the same with the three trailer vent covers that I've installed......
Old 02-10-2016, 12:12 AM   #14
asquared's Avatar
On our old tt we had the max air II vents. We had a white one over the bathroom and a smoke one over the bedroom. The white one was cheaper. The smoke one let in a little less light and we could see out the vent over the bed better. We let them go with the old tt. The fiver has a black one over the bathroom vent because that was the color they had. I like the black one the least but it doesn't really matter. Get the one that matches your trailer the best. Here is a pic of my old tt. The front grey hump is the smoke cover. You can see the rear white one easier from the single the pic was taken.
<a href=https://i62.tinypic.com/28rp645.jpg target=_blank>https://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
Old 02-10-2016, 12:43 AM   #15
Phat Phrog Stunt Crew
elind's Avatar
2015 Columbus 320RS
2008 2500HD Duramax
Sounds like you want it dark in the playroom!!
2014 Wildcat 327ck
elind is offline   Reply With Quote
Old 02-10-2016, 07:00 AM   #16
TURBS's Avatar
Sounds about right!
2015 Columbus 320RS
2008 2500HD Duramax
Old 02-10-2016, 07:23 AM   #17
MaxAir covers have 6 year Warranty,but I have seen RV's parked way longer than that with MaxAir covers that still looked New,they were all white though! Youroo!!
Old 02-10-2016, 07:31 AM   #18
AquaMan's Avatar
I had white ones on our Sierra along with the vent pillows with the reflective foil on one side. Did a great job keeping heat and cold out. I also installed the Vent Stik knobs on the vents, as most were taller than I could reach. The Stik helped with installing and pulling the pillows out also.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
Old 02-10-2016, 05:28 PM   #19
2015 Columbus 320RS
2008 2500HD Duramax
Very nice
Old 02-10-2016, 05:30 PM   #20
I Break Everything
mikel68's Avatar
Black for us, Our MH is black, plus less heat through them. Texas gets hot.
2015 Georgetown Forest River 351DS Class A
2008 Keystone Cougar 293SAB 5th Wheel
2007 Jay Flight 30.5RLS 5th Wheel
2006 Jay Flight 29BHS TT
mikel68 is offline   Reply With Quote
black, cover, vent
