Old 04-01-2012, 01:31 PM   #41
Fire Instructor's Avatar
I "de-winterized" my system today (for the first time), and had a fault on my solar controller that took me a while to figure out. I take my batteries out, and store them in the house basement in the winter. I didn't realize that the controller temp sensor had to be connected to the battery before any power was connected, or the controller display acts irradically. So after re-reading the manual, I disconnected everything, made sure that the panel disconnect was in the off position, connected the temp sensor, and then the power, and the controller STILL showed the fault....
So I disconnected the power AGAIN, and RE-READ the manual, and couldn't find any that I was doing wrong. I took a big breath, had another cup of coffee, and figured I'd try again. I happened to look at the display on the controller with the battery disconnected, and it STILL read "fault", so now I'm REALLY confused.... How can the controller read "fault" with no power??? On a whim, I reached over and turned on the 120v inverter... it came on.... confusion turning to frustration, I flipped on the ceiling fan, and it came on. So is the trailer haunted? Did my wife or someone else plug the TT into the garage while I wasn't looking?????
That's when the "DUH! I sure am STUPID!" thought came into my mind. The TT was still connected to the tow vehicle, and was drawing 12v supply from THERE! Unplug the TT, make sure that the battery is completely disconnected, reconnect everything in the PROPER order, turned the disconnect for the panels back on, and VUALA! Everything functions properly....
I'm now charging my batteries again, with nothing plugged in!
And the BEST news of the week is that as a "second home", (I claim the loan interest on the TT on my taxes as such), my accountant took ALL of the receipts from my solar installation, so that they could be factored into my taxes as a "renewable energy" home improvement!!!!
Fire Instructor
2014 RAM 2500 Laramie 4x4 Quad Cab w/Cummins Turbo Diesel, 2009 Rockwood 2607, and 3 'yaks!
300W of Suntech Solar, a Rogue MPT-3024 Controller, and a Xantrex PW2000 Inverter
Fire Instructor is offline   Reply With Quote
Old 04-01-2012, 01:45 PM   #42
Drinkin beer on the beach
Rod Johnson's Avatar
Fire, do you run your fridge on electricity, or strictly propane?
2014 Silverado 2500 6.6L TD and 4X4
2011 Carson Standard Duty Car Hauler
2012 Forest River Stealth SK2112
Rod Johnson is offline   Reply With Quote
Old 04-01-2012, 02:05 PM   #43
When in the driveway, between trips, I plug the TT into the garage, so that that all outlets have 120v and the fridge doesn't burn propane. I keep the 12v inverter breaker on the inverter panel off, so it just acts as a distribution point for 120v, and all 12v comes from the batteries, being recharged by the solar. The solar easily handles all of my lighting use and the parasite loads, between trips.
While traveling or camping, the fridge runs on propane, unless I happen to be at a CG with electric available.
Fire Instructor
Old 04-01-2012, 02:31 PM   #44
And, did you fuse the leads from your solar panels to your charge controller?
You mentioned a disconnect for your solar array. Where and how did you install that? I was thinking about using the same battery disconnect that Forest River uses and installing that next to my charge controller?
Or, would a heavy duty switch like this (I have one that switches most of my outlets from shore power to generator power)
Switches | Wall Switches | Bryant 3025I Industrial Grade Toggle, Double Pole, Double Throw, 30A, 120/277V AC | B211353 - GlobalIndustrial.com
Sorry for the all the questions, just trying to make sure I get all the parts ordered.
Old 04-01-2012, 03:38 PM   #45
No. I saw nothing in my research that recommended or required it.
If you look at the photos, linked in the original post, you can see the disconnect inside a hanging closet, directly below the roof mounted junction box and the controller. TI used a marine-grade disconnect, like
this one: Amazon.com: Perko 9601DP Marine Battery Disconnect Switch: Automotive
That Bryant switch is an AC switch. You need a DC switch. The marine switch seemed to me to be the best use/best value.
[/QUOTE]Sorry for the all the questions, just trying to make sure I get all the parts ordered.[/QUOTE]
Thank you for the interest, and I hope that I helped you!
Fire Instructor
Old 04-06-2012, 09:49 AM   #46
Bennington Camper's Avatar
If you disconnect the source circuit conductors (those from your PV) under load, you will pull a DC arc in your switch. Very few switches are rated for this 'load break' arc. Each operation will burn off contact metal, and at some point probably weld the contacts.
The switch will be fine if there is no load on the array - the charge controller in this case provides the load. Would be OK after dark, if the module(s) were covered, if the charge controller was not charging, or turned off (if this is an option).
Fusing in the source (or output strings if combined) is necessary if a short in the DC wiring could cause more than the individual module fuse rating (printed on the back of the module, and usually on module cut sheets). This is usually if more than 2 modules are wired in parallel (or 2 strings of modules if using a MPPT charge controller).
Glenn
Technical Specialist
Real Goods Solar
NABCEP Certified PV Installer
NYSERDA Eligible installer
Adjunct instructor Hudson Valley Community College
Glenn - KA2DTH
2007 Chevy Express 1500 AWD
2005 Surveyor SV-230
Bennington Camper is offline   Reply With Quote
Old 04-06-2012, 10:24 AM   #47
Inverter to battery wire sizing is done using the full rated power of the inverter (2000W) divided by its lowest rated DC voltage (let's say 10.5VDC), multiplied by the inverter's efficiency at that power (probably not its most effecient point of operation, let's say 85%).
(2000W / 10.5VDC) * 0.85 = 162A
Because you never want to push your conductors to their limits (and the NEC says so), you must upsize this so there is a 20% safety factor.
162A * 1.25 = 138A
Then this number would be modified by other conditions of use, such as if it were in a conduit, exposed to high temperatures, etc.
Using the tables in the NEC for the type of wire to be used, you would pick a size larger than this number. By the way, 138A would be the value you would use for fuse sizing and DC battery disconnect as well.
Also note that no voltage drop consideration was done on this calculation.
If the wires are to be used outdoors, be sure to select an insulation suitable for that application.
2 AWG UF copper conductor would be suitable for this with an ampacity of 140A.
Glenn
[QUOTE=Fire Instructor;145740]Yes. I've drilled a total of five holes in the floor in that area. The first pair was to bring the new #4 cables from the battery to the inside compartment junction box. I also drilled a hole and ran the factory positive and ground (originally connected to the battery) into the same box PLUS a twisted pair control wires for the controller, PLUS the battery temp monitoring wires for the controller. (Six small wires
Glenn - KA2DTH
Old 04-06-2012, 10:28 AM   #48
Not likely this is an MPPT controller. Specs are for a 12VDC input - MPPT uses higher than the battery voltage...
Glenn
Glenn - KA2DTH
Old 04-06-2012, 10:31 AM   #49
The below listed switch seems to only be rated for AC.
Do not use AC only switches on DC circuits - DC arcing will weld the contacts - AC crosses zero volts 60 times a second and is easier to quench, thus more cheaply made.
-Glenn
Glenn - KA2DTH
Old 04-07-2012, 07:01 AM   #50
Herk7769's Avatar
Originally Posted by Saratoga Camper View Post
Inverter to battery wire sizing is done using the full rated power of the inverter (2000W) divided by its lowest rated DC voltage (let's say 10.5VDC), multiplied by the inverter's efficiency at that power (probably not its most efficient point of operation, let's say 85%).
162A * 1.25 = 138A
I understand that the "equalizing" of AC/DC wattage requires the power factor be used. I get your calculation logic (2000W / 10.5 VDC) * 0.85 = 162A However I am not following your 20% safety factor math. 162A * 1.25 = 138A (think an error was made here)
As I understand what you are trying to say though, adding a 20% safety factor means either "upgrading the wires to handle a load 20% greater than the maximum rated load; yet fusing for 100%" (Wire size based on 195 amps and fuse based on 162A - which I get) OR (Wires size based on 162A and fused for 130A (20% less than full load).
If you were to use 1.0 as a power factor, 2000/10.5 = 190 amps and fuse (15-20% less or 162-175A) accordingly it pretty much wipes out the power conversion factor and the safety margin math. Makes things easy for me.
In fact to make it even easier, if you use 12 VDC and a 1.0 power factor, the amp load is 2000/12*1 which equals 166 amps. Right about where you want your circuits fused.
HAM CALLSIGN - KC3FFW
12 volt, solar
