Old 03-22-2016, 04:04 PM   #1
acadianbob's Avatar
Victron 700BMV Install
A friend of mine talked me into installing a Victron 700BMV battery monitor in our new Surveyor. I'm totally impressed with it. You put in your total amp/hrs of your battery bank and it measures amp/hrs used. It thereby determines the percent of charge remaining in your battery bank. It also show amp draw. So, you can switch things on, one at a time, and determine the amp draw of everything in the trailer. When charging, it measure amp/hrs returned to the battery bank and shows the amp rate of charge. No more guessing about usage and state of charge. This thing is awesome.
2012 F150 FX4 Ecoboost, 2016 Surveyor 274BHS
2003 Yamaha FJR1300, Demco Premiere Slider
Red Green coffee mugs
Old 03-22-2016, 07:06 PM   #2
They are awesome. I just installed the 702 version which allows monitoring the voltage of a second battery. I also installed AGM group 31 batteries replacing the flooded group 27's that were off-gassing and setting off the LP/CO detector.
I use the aux input to monitor the chassis battery.
Should be a great addition to the Motorhome.
KatanaPilot is offline   Reply With Quote
