05-14-2013, 06:22 PM
Denver, CO
Victron battery monitor
Just bought a Victron BMV 600 Battery Monitor from Jamestown distributors for $144. It's a frickin thing of beauty, has an intelligent shunt that connects with one Ethernet type cable, no extra wires. I will install tomorrow.
I think they make the link monitors according to somebody. It seems like a great unit. Sometimes the marine stuff is pretty close price wise and is generally made a little better than the RV STUFF.
2017 Fuse 23T
05-15-2013, 12:21 AM
please post installation and followups of this... this is on my research list for my rig as well.
himcules (10x stronger than hercules)
2013 Forest River Berkshire 390BH-60
ex 2007 Jayco Greyhawk 31SS
05-15-2013, 10:42 AM
Denver, CO
Will do. Should be a simple install, but I always say that.
2017 Fuse 23T
05-16-2013, 06:27 PM
Denver, CO
It was a simple install, took two hours and much of that was threading the single wire from the battery compartment to the back of the kitchen cabinets. The whole install consists of a 2 inch hole for the monitor, a couple of screws for the shunt, running the wire between the shunt and monitor, and hooking a supplied red wire with from the positive Battery terminal to the shunt, AND finally running a short ground wire from the battery to the shunt and from the shunt to the distribution post.
Really easy and the darn thing reads everything, does it's own calculation on state of charge etc. (or you can set it manually). I'm quite impressed.
Pics before and after below...
2017 Fuse 23T
05-16-2013, 06:33 PM
I see you have a Blue Sea battery cut off switch. I am looking into getting one as well.
I may look into this battery monitor as well, the install looks great. Is that two twelve volts hooked up together?
05-16-2013, 06:36 PM
nevermind.. i looked up the install instructions for the victron and understand the wiring pic now...
victron shunt goes inline on the negative to ground...
05-16-2013, 06:57 PM
Originally Posted by
Himcules
Same as the TriMetric TM 2025RV Monitor.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
05-17-2013, 07:31 AM
Wanna Be Camper
That is one sweet looking piece of equipment.
John & Deb
2011 Flagstaff V-Lite 30WRLS
05-17-2013, 07:35 AM
TheSasks
John, if you are talking about the TM the second "B" line can also be used to monitor solar output voltage instead of a second battery bank.
http://www.forestriverforums.com/for...itor-5436.html
I apologize for the hijack. Won't happen again...
05-17-2013, 05:57 PM
Denver, CO
Grizzlygibbs
I love the blue sea bat switch, works great. I have 2 deka GC15 6 volt batts in series. I got a real nice battery box with a top and bottom vent.
2017 Fuse 23T
» Recent Discussions
