Old 03-06-2015, 02:48 AM   #1
Texas Realtor's Avatar
Wanting to add residential refrigerator
My Dometic is too unstable on temp as some days 32 degrees than wake up next morning and 50. Wife does not like. I am wanting to pull it and add 19.7 French door whirlpool that 68.5 inches tall as they sit on furnace in my 2011 berk 39bh and I thought I had extra 6 inch space above current Dometic but found some type of casing and cannot get height to ceiling I want. Any suggestions on what that is and how I can do this. My Rv tech said I need a 64 inch high refrigerator as that makes very small 15 cu top freezer which is bummer for mod I wanted to do.
Texas Realtor is offline   Reply With Quote
Old 03-06-2015, 06:02 AM   #2
davel1971's Avatar
looking at Lowe's website, they have 114 refrigerators between 62 and 65.5 inches, in top freezer, bottom freezer and french door models. Just watch the depth too. You will likely want counter depth.
David & Lynn
Old 03-06-2015, 06:50 AM   #3
Would be cheaper to add fans inside and outside the frig. I did and it maintains 33 -36 in frig and 4-6 in freezer.
Old 03-06-2015, 06:58 AM   #4
TURBS's Avatar
X2
ugh this agreeing thing has to stop!
Old 03-06-2015, 07:13 AM   #5
Originally Posted by TURBS View Post
X2
I figured you would finally see the light!
Old 03-06-2015, 09:32 AM   #6
Jim34RL's Avatar
You also will need an Inverter that will supply the 120 volts for the residential refrigerator.
I have a 18 Cu. Ft residential refrigerator in our Cedar Creek and an option of a 20 Cu. Ft SS with Inverter is available from Forest River also. You might be able to contact Forest River for a refrigerator for your needs. Just a thought.
Jim W.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 112K+miles
Old 03-06-2015, 11:51 AM   #7
I understand a fan inside the Frig ,,,where do you put the inside fan??
Dogpound is offline   Reply With Quote
Old 03-06-2015, 12:22 PM   #8
TURBS's Avatar
I mounted mine to the cooling fins
Old 03-06-2015, 12:55 PM   #9
I have 110 volt ref and most of the time it is great lots of room. and keeps everything cold. I have a 1000 watt inverter .not sure it is big enough if buy 1 buy 1500 watt.
wire1946 is offline   Reply With Quote
Old 03-06-2015, 01:15 PM   #10
Dual fans hanging off the cooling fans inside and dual fans blowing up from the very bottom of the frig on the outside. All 4 fans are on anytime the frig is on whether on gas or electric.
Name:	Dual fans2.JPG
ID:	70838   Click image for larger version
Name:	One 80mm and one 90mm.JPG
refrigerator
