Old 01-31-2015, 09:43 AM   #11
Flybob's Avatar
One word of caution. If you get in the habit of leaving the electric switch "on" all the time, you need to be careful that you don't drain the WH and then plug in to shore power before refilling it. This is easy to do if you plug in at home while packing for a trip or while cleaning after one. A simple reminder tag on your shore power connector will remind you. I use a small "Remove before Flight " tag available on ebay for < $11.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 01-31-2015, 09:45 AM   #12
cat1956's Avatar
This is the switch I put in my 27rlws
Tommy and Wanda
2014 Flagstaff 27RLWS
2017 Ram 1500 5.7 Hemi
Equal-i-zer 1,200/12,000 Weight Distribution w/ 4-Point Sway Control
cat1956 is offline   Reply With Quote
Old 01-31-2015, 01:18 PM   #13
pt1655's Avatar
offroad,
Geez, what a great, somewhat easy idea! My electrical panel in our Surveyor is very close to a great spot to mount a switch so your idea may work very well! I was having headaches trying to figure out how to access the outside switch and run wire inside, etc. Thanks!
Pete
2013 Forest River Surveyor SP220 Sport 25'
2012 Ram 1500 4X4, 5.7L Hemi quad cab
pt1655 is offline   Reply With Quote
Old 01-31-2015, 02:26 PM   #14
jtownstumpjumper's Avatar
Location: Jonesboro AR--Home of Arkansas State University and the Red Wolves
Okay, I think I follow your comment, but for someone who's installed a second on/off switch in the control panel and it's OFF then it shouldn't matter that the on/off switch outside is ON, correct?.....one shouldn't have to worry about the water heater when you hook to shore power because it shouldn't come on....is this correct thinking?
Lloyd & Kathy Martin
2018 Forest River Palomino Columbus 383FB
2016 Chevy 3500HD SRW Z71 LTZ 4WD Crew Cab, DuraMax/Allison.
2014 - 38 nights/3500 mi.; 2015 - 66 nights/6260 mi.; 2016 - 44 nights/6106 mi...
2017-65 nights/6992 mi.; 2018-47 nights/7376 mi; 2019-11 nights booked
jtownstumpjumper is offline   Reply With Quote
Old 01-31-2015, 02:52 PM   #15
The "new lighted switch" is installed between the breaker in the electrical panel and the on/off switch located at the water heater. The new switch controls the power to the tank, so leave the tank switch in the on position. When breaking camp, turn the "lighted switch" off (no light showing) and you are good to go. I have made this mod to my trailer and it works great.
Bob
2013 Ford F250 SD 6.7L
2014 Wildwood Heritage Glen 282RK
Certified Rumble Strip Tester
retiredcamper47 is online now   Reply With Quote
Old 02-01-2015, 07:21 AM   #16
wmtire's Avatar
That would be correct, as the ones who have made this mod have stated.
I am going to point out one thing for maybe newer inexperienced members (reading this topic later), that really doesn't have anything to do with the mod topic at hand, but the electric heating element on the Suburban water heaters in general.
When the electric heating element is energized (the thermostat calls for heat), it will draw about 12 amps of electrical. If you are on a 30 amp power supply, then you will be limited as to what other electrical things can be used at the same time, as you will need to keep it around the 18 amp mark to keep from possibly overloading circuits and/or tripping breaker(s). 18 + 12 = 30 amps. Another way to think of it is, the electric heating element will use 40% of your available power, when it's energized and heating the water.
You will have to practice energy management, and learn what can be on (and thus what has to be off) at the same time to keep from overloading the power supply/breakers. If the breaker(s) trip, then you know that you are overloading something....but I always hate to put blind faith in the breakers tripping.....thus it's good to know in your head what you should/shouldn't use at the same time. Your air conditioner, microwave, and electric water heater element are 3 of your biggest factory installed RV electrical usage items. Most times, all 3 of these cannot be on at exactly the same time, without overloading a 30 amp supply.
Mark Polk has a great article here that really explains the 30 amp power supplies near the bottom:
http://rvservices.koa.com/rvinformat...lectricity.asp
Good thing is, with this mod, you can easily turn off the electric heating element without going outside....... when you need to turn it off (or make sure the heating element doesn't come on while other things are in use) ...... so you can use other electrical things and stay within your 30ish amp thresh hold.
2011 Flagstaff 831 RLBSS
Never Apologize! Never Explain!
Sorry, thatís my motto.
Old 02-23-2015, 01:20 PM   #17
i would like to know how to ask a question of someone who owns a forest river rv?
mstephenson is offline   Reply With Quote
Old 02-23-2015, 01:23 PM   #18
i guess i could just explain my problem, i am trying to find out if i have a gas and electric hot water heater. i have been outside to the heater itself and there is no black rocker switch on the heater itself and i do not have a breaker labeled inside for a hot water breaker. i have been told that it should be both? thanks
Old 02-23-2015, 01:26 PM   #19
If you list the model and part number of the water heater I sure someone could give you an answer.
Ontario
Vibe 6501
1 Prospector Canoe
2 Mtn. Bikes
4 Hiking Boots
Happy Vibe is offline   Reply With Quote
Old 02-23-2015, 01:27 PM   #20
You could write down the nomenclature and research it?
2018 XLR Nitro 36T15
2015 GMC 3500 6.6/Allison
Nights Camped (2018-16) (2017-16) (2016-13) (2015-13)
SuicideSaints is offline   Reply With Quote
electric, heater, water, water heater
