Old 01-30-2015, 07:43 PM   #1
jtownstumpjumper's Avatar
Location: Jonesboro AR--Home of Arkansas State University and the Red Wolves
Water heater electric switch question..
I followed a thread back a few months ago related to the electric on/off switch on the water heater and the discussion was how to move this switch from the outside water heater compartment inside the unit and put one in the control panel....with our 2014 Silverback33RL, if you want to run off propane, you have to go outside and turn off the electric switch, then back inside and turn on the propane water heater switch......I cannot find the thread now and was wondering if someone can help....thanks.
Lloyd & Kathy & Kit(19 yr old cat)
2018 Forest River Palomino Columbus 383FB
2016 Chevy 3500HD SRW Z71 LTZ 4WD Crew Cab, DuraMax/Allison.
2014 - 38 nights/3500 mi.; 2015 - 66 nights/6260 mi.; 2016 - 44 nights/6106 mi.
2017-65 nights/6992 mi.; 2018-7 nights/1037 miles....9 nights booked
jtownstumpjumper is offline   Reply With Quote
Old 01-30-2015, 08:30 PM   #2
offroad's Avatar
Just put a light switch in the circuit that goes to the breaker for the hot water heater.
Mount it anywhere that's convenient between the breaker and the hot water heater.
Then leave the a/c switch outside in the on position and use your switch to turn the hot water heater on and off.
2017 Open Range - Light 297RLS, BX1 Gooseneck
2014 Ram 2500 4x4 CCSB 6.7L 68RFE
offroad is offline   Reply With Quote
Old 01-30-2015, 08:41 PM   #3
wmtire's Avatar
Is it this one by Iggy:
Added Inside Switch for Water Heater
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 01-30-2015, 08:45 PM   #4
I believe it is....thanks.
Old 01-30-2015, 08:56 PM   #5
caper's Avatar
You can leave the switch on and run the propane at the same time. Some people use the breaker in the panel to turn off the electric side of the WH.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 01-31-2015, 05:27 AM   #6
fonzie's Avatar
Here is another thread.....
Water Heater Switch with Power-on Light
Fonzie
Old 01-31-2015, 06:00 AM   #7
cpaulsen's Avatar
Installed a lighted switch on mine and always leave the little black switch in the on position at the water heater. I never turn it off when using propane which I very rarely use.
cpaulsen is offline   Reply With Quote
Old 01-31-2015, 07:06 AM   #8
sail2liv's Avatar
I leave my hot water heat switch on all the time....I only turn it off when I don t need amps on system or draining....if need to turn off without going outside I just flip the breaker inside.....so far no problems running the gas and electric together....or gas by itself.....if no 110.....everything working in my unit so not going to touch anything in system....intention of making things better is not always the outcome when fiddling...
2011 Silverado 2500HD 6.0 Gas 3.73
2013 Flagstaff 8524 RLWS
1978 Cape Dory Ketch
sail2liv is offline   Reply With Quote
Old 01-31-2015, 07:17 AM   #9
Kaadk's Avatar
Like other's have said, you don't need to turn of the electric side when you run propane. Only if there's no water in the tank. I leave my electric on all weekend, but occasionally flip to propane when showering to boost the recovery time. Shower done, just turn the propane off and leave it running on electric.
There's no use crying over spilt milk, unless it's on your keyboard.
Kaadk is online now   Reply With Quote
Old 01-31-2015, 08:41 AM   #10
DDC
DDC's Avatar
I use both when we can but I like to turn off the electric side when we are leaving so I don't get the arcing when I plug in the next time.
Cedar Creek Silverback 33IK
Donald&Casey cairn terrier
DDC is offline   Reply With Quote
electric, heater, water, water heater
