Old 04-18-2014, 04:41 PM   #11
Brother Les's Avatar
Originally Posted by RJHuser View Post
To get back to the mod, are those fittings and hose rated for the temperature of the hot water? If not, I see a minor disaster in the making when they fail.
Rick
It is not a hot water hose and will have issue down the road.
Brother Les
Old 04-18-2014, 05:55 PM   #12
shadow7663's Avatar
Rick
The plastic fittings are made from the same material as the stock plug from the manufacture ( Atwood ) The hose is rated to 125 Degrees F and the Atwood WH are set at 120 Degrees F at the factory. Also the brass ball valve will with stand much higher temps.
2014 PrimeTime Avenger 33BHS
2005 Dodge Ram 2500 4x4 Quad Cab 5.9 Cummins
12k Equal-I-zer hitch
shadow7663 is offline   Reply With Quote
Old 04-19-2014, 07:12 AM   #13
Garrette's Avatar
I think all water heaters have an anode. May be inserted from the top.
Garrette is offline   Reply With Quote
Old 04-19-2014, 07:23 AM   #14
Nope,not all! Youroo!!
youroo is online now   Reply With Quote
Old 04-19-2014, 07:53 AM   #15
2014 XLR 27HFS
Love those simple mods that are cheap and make life easier, nice job. Like DSRACE, I drain the heater and complete water system after each trip unless going right back out again.
Dave & Audrey
dave961 is offline   Reply With Quote
Old 04-19-2014, 08:00 AM   #16
KyDan's Avatar
Nice mod. Good pictures. Thanks for sharing!
One thing comes to mind-- if you drain it every time you also have
to remember to shut off the electric heater EVERY time.
(And the LP gas switch too!)
Happy Camping!
Peace!
Dan & Rita D
Blue Ox WD hitch
KyDan is online now   Reply With Quote
Old 05-11-2014, 01:07 PM   #17
BruceM's Avatar
Stagnant water in the hot water heater?
Is there really such a thing?
Even if it did occur, do you drink from the water heater?
If not, then I assume you think this "stagnant" water is harmful to use for washing?
Inquiring minds want to know.
2015 Rockwood MiniLite 2109S
2018 Ford F150, 3.5L ecoboost
Blue Ox SwayPro hitch
BruceM is offline   Reply With Quote
Old 05-11-2014, 01:38 PM   #18
TURBS's Avatar
Happy Camping!
Wouldn't you have to shut them off anyway?
TURBS
Sabre owners united!
Old 05-11-2014, 02:20 PM   #19
Iggy's Avatar
I just drain my water heater tank by removing my anode. Flush out any garbage and reinstall anode for my next trip. This way I always know the condition of my anode.
Old 05-11-2014, 02:36 PM   #20
TURBS's Avatar
Ditto.
TURBS
drain, heater, water, water heater
