Forest River Forums
Sunline User Photos
Old 08-29-2011, 07:54 PM   #1
Steve38's Avatar
Water pump advice
I'm looking for advice on water pumps. I was looking at them in Camping world and the prices are all over the place. I want a quiet pump, pressure is not an issue. Are the more expensive pumps any quieter then the OEM pumps the trailer manufacturers install? Is it worth upgrading to a new more expensive pump?
2011 F150 Ecoboost
2012 XLR 27HFS Toy Hauler
pho217@aol.com
Steve38 is offline   Reply With Quote
Old 08-29-2011, 08:35 PM   #2
camping
tentcamper1's Avatar
I have the Shurflo classic series pump and put some rubber grommets under the feet where the screws attach it the floor and it helped quiet it down by half or better. could try that and see if it works for you.
2007 Chevy 2500HD CC
2010 V-Lite 30WRLTS
Nights Camped 2011 -64
Nights Camped 2012 - 16
"I Live in My Own World, But It's OK. They Know Me"
tentcamper1 is offline   Reply With Quote
Old 08-29-2011, 09:21 PM   #3
too fast turbo sled
f1100turbo's Avatar
make sure you get one that "runs" dry without damage ! built in check valve . and self priming .
shurflo is a good bet
2005 silverado 2500hd pro ride 5th
2011 palomino sabre 32 bhok-6
2012 arctic cat f1100 turbo limited edition sno-pro
Ron and Amy Benhart
2012 nights camped (5)
f1100turbo is offline   Reply With Quote
Old 08-29-2011, 10:40 PM   #4
kevinC's Avatar
I have a Shurflo and I did the same thing and mounted with medium hard rubber grommets about a 1/2" thick. It sure made a big difference on the noise. And a check valve and self priming (which most are) are a must IMHO.
2006 T23FBL Wildwood Lite
2009 Ford E-350 Super Duty 5.4L 3.73
kevinC is offline   Reply With Quote
Old 08-30-2011, 06:13 AM   #5
Steve38's Avatar
Thanks for the rubber mount mod, I will try it before buying a new pump.
2011 F150 Ecoboost
pho217@aol.com
Old 08-30-2011, 06:23 AM   #6
volunteer moderator
While you're in there adding the rubber grommets get some foam
pipe insulation. It's slit longways and easy to cut into short pieces.
Look for anywhere a water line is possibly
touching a wall, floor, bulkhead, water tank etc..... Put foam on the
area that might be touching. Fasten with zip ties or just recycled twist
ties. Have someone run a little water while you watch the water lines.
Notice how they jump in tune to the beat of the water pump??
Make SURE they can't drum on anything around them!
Remember, if it's moving it's probably making noise. Secure as many as
you can with foam and you'll probably notice a big improvement.
Good Luck!
Peace!
Dan & Rita D
2008 Rockwood 2502 Ultra Lite
2004 5.3L Silverado 1500 ext. cab 2WD
Reese dual cam hitch, AirLift load levelers
53 days camping in 2010, 47 in 2011, 12 in 2012
Old 08-30-2011, 06:48 AM   #7
Lou Amadio
herk7769's Avatar
My experience is similar.
The OEM pump could definitely be quieter, but 90% of the noise is mounting and pipes.
The plumbing is the noise maker. Adding an air chamber helps as well.
Amazon.com: SHURflo Accumulator Tank: Automotive
It is an easy mod. I replaced my "whole camper" water filter with one and never looked back. I use an inline filter on the spigot at campgrounds that use well water to remove silt.
Lou and Laura Amadio and Bella the German Short Hair Pointer
2010 Flagstaff 8526RLWS 5th Wheel Pullrite Hitch
(2009: 28) (2010: 74) (2011: 93) (2012: 7)
herk7769 is offline   Reply With Quote
Old 08-30-2011, 09:06 AM   #8
miatared's Avatar
I mounted mine on a mouse pad, it cushions well.
I also installed a ShurFLO accumulator tank.
I left the supply line long enough to coil it a few times before it feeds the water the tank.
Denis
2011 Flagstaff Shamrock 19 aka Sham Wow
2009 Toyota Highlander Sport
miatared is offline   Reply With Quote
» Online Users: 521
73 members and 448 guests
02 rockwood, 2007Rockwood2601, 4bnabird, 4Jeeperz, 64c10, 8261ss, Barnman1, Bearcat55, bfisher82, bob7794, buzzmonster, campfun, Claude C, CRZ, cstover, dashonthedash, DDC, ddemme, DonG, Emptypockets, fonzie, Freds342, gerrym51, GlacierGus, Greene, ilovecamping, jjacon, kenandterry, Kentdb1, kgmat, lindy, Linnemj, Mad4sax, mamentt, Marc73, Mike G, mike1329, NeilM108, nightcrawler, NO3putt, patov6, Poppy Bill, prof_fate, punkaccountant, RattVader, RichN, RickV, rkswyo, Roamin Ovum, Rsgtivr6, Rugged Brown, Rustymax, ryoucrazey, seatosea, ses, shiggs, Smithee, SnowBird9, Sparkbark, SpringerPop, Stank Bait, Stedman1, steeleshark2, Stevea1956, terrystevens, tfennell81, tgarner2000, tking1866, torben, transamz9, vp22er, Walke, Whiteknight
Most users ever online was 1,025, Today at 01:04 PM.
Close [X]
