Originally Posted by revrnd
The 3 fittings that are threaded into my fresh water tank are elbows. Currently the fitting that feeds the water pump is 2" off the bottom. I had the fitting out today & there is no pick up hose on the "tank side". As a result, the pump starts running dry when there is still a lot of water in the tank.
I was wondering if I could swap the elbow for a T fitting (if available) @ tank drain (lowest point) and connect the water pump feed to it?
I think that is a good mod as well!
The only reason I can think of why they would do that is in case of possible sediment/solids/dirt in the tank? So that pump, plumbing and subsequently human consumer will not have to deal with? I dunno.
