Old 12-05-2012, 11:40 AM   #11
jim44646's Avatar
I have the shear, crimpers and ring cutter. started using pex in house. So much simpler
jim44646 is offline   Reply With Quote
Old 12-05-2012, 01:27 PM   #12
Herk7769's Avatar
The Sharkbite fittings do not use the rings and crimp.
They just push on and you are done.
HAM CALLSIGN - KC3FFW
Old 12-06-2012, 03:49 AM   #13
If you use (Pink RV) fluid in your lines also,place a shutoff valve on discharge side of pressure tank,after draining tank,close valve to keep pink out of tank. Youroo!!
youroo is online now   Reply With Quote
Old 12-06-2012, 07:03 AM   #14
Herk7769's Avatar
That is an excellent idea. Late; but excellent.
There will be a valve in that line next year.
Old 12-06-2012, 08:19 AM   #15
Newly retired and ready
Wouldn't you put the shutoff on the line prior to the tank so the antifreeze didn't get to the tank. Maybe I don't understand what you mean by the discharge side of the tank. A diagram would be fantastic. Appreciate your help as I don't want to mess this up
Gary, Susan, and Molly(the dog)
2007 Ford F-250 V10
2010 Flagstaff 8524 RLS
Gl111349 is offline   Reply With Quote
Old 12-06-2012, 08:31 AM   #16
There is only (1) inlet-outlet on the bladder tank. Youroo!!
Old 12-06-2012, 08:52 AM   #17
I posted the install a long time ago,tried to go back to it but could only go back (500) posts! How do I go back deeper? Youroo!!
Old 12-06-2012, 09:16 AM   #18
Understand now what you meant. Thanks again for your help. This is going to be a great modification for my 5th wheel.
2007 Ford F-250 V10
Old 12-06-2012, 09:33 AM   #19
Youroo and Herk, could you take a look at this diagram and see if you think it will work. I am not a plumbing expert by any stretch of the imagination so any help would be appreciated.
Name:	Pressure tank install.jpg
2007 Ford F-250 V10
Old 12-06-2012, 10:14 AM   #20
jim44646's Avatar
Herk
I know Sharbites don't use crimp rings. My meaning was when doing a whole trailer or house they can get expensive. I have the tools because of this. A Sharkbite 1/2 Tee is $10.25 a pex tee is $1.95, A Sharkbite 1/2 elbow is $7.50 pex elbow $1.50. Redid a whole house last winter, hate to see what it would have cost using Sharkbites. I have used Sharkbites for quick repairs.
Jim
