Old 12-03-2012, 02:46 PM   #1
Herk7769's Avatar
Water Worker Accumulator
I previously replaced my water filter with a Shurflo Expansion bottle, but the volume of water dispensed prior to the pump coming on was not very much.
(Basically a 1 or 2 second flush).
I wanted more water before the pump ran so was looking to install a bigger expansion pressure tank. The Water Worker 2 gallon tank looked like the way to go. Water Worker - Water Heater Expansion Tank
I removed the Shurflo Tank by unscrewing the connections I made when I took out the old water filter and the tank came right out.
The new tank plumbing was done with all Sharkbite press on connectors and a section of PEX I keep in the camper.
Total install time was about 1 hour start to finish.
ID:	21991   Click image for larger version
ID:	21992   Click image for larger version
ID:	21993   Click image for larger version
ID:	21994   Click image for larger version
ID:	21996   Click image for larger version
ID:	21997   Click image for larger version
ID:	21998   Click image for larger version
ID:	21999   Click image for larger version
HAM CALLSIGN - KC3FFW
Old 12-04-2012, 08:40 PM   #2
Newly retired and ready
I just bought the exact same tank through Amazon. Cold here in Iowa so I will probably wait until spring to install. Question, did you install with the tank on its side or vertical with the inlet at the bottom. I bought a drop ear tee so I could install vertically and screw it to the floor. Also plan to use pex and shark bite connections to hook up. Anything else you can alert me to be aware of? Thanks
Gary, Susan, and Molly(the dog)
2007 Ford F-250 V10
2010 Flagstaff 8524 RLS
Gl111349 is offline   Reply With Quote
Old 12-05-2012, 07:04 AM   #3
Herk7769's Avatar
The important thing is access to the Shrader Valve at the end of the tank and the ability to drain the plumbing when winterizing.
In my installation mounting it vertically in my 5th wheel's front basement would have been a plumbing nightmare and I would not have had easy access to the valve and would have had to attach it to its own drain valve.
I mounted it on its side and strapped it to the roof of the compartment.
The rubber bladder goes all the way to the end of the fitting when empty, so the only water that needs to be drained is in the pipe itself. Since I mounted it on the roof of the compartment, I was able to angle the pipe so it drains with the rest of the plumbing.
Old 12-05-2012, 07:25 AM   #4
jim44646's Avatar
What would we do with out Sharkbites????????
jim44646 is offline   Reply With Quote
Old 12-05-2012, 07:44 AM   #5
Herk7769's Avatar
I would have to try and remember how to solder pipe joints again. Ugh.
PS, have you seen the price of copper pipe?
The comment from "The Graduate" comes to mind.
"Plastics, my boy, Plastics!"
Old 12-05-2012, 07:45 AM   #6
I can now see where your horizontal install is much better. Thanks for the idea and am anxious to try it out
2007 Ford F-250 V10
Old 12-05-2012, 08:06 AM   #7
I did the same thing with a spare pressure tank from my well somewhere around 2006. I removed the tank from the last fifth wheel when we traded it and added it to the new one before our first trip. Never regretted it.
Filthy Beast is offline   Reply With Quote
Old 12-05-2012, 08:08 AM   #8
Herk, what pressure did you set the tank at?
2007 Ford F-250 V10
Old 12-05-2012, 08:14 AM   #9
jim44646's Avatar
Pex is so much easier than copper even without Sharkbites.
Tools a little costly but once you have them they will pay for them selves.
Old 12-05-2012, 09:57 AM   #10
Herk7769's Avatar
I used 30 PSI. As to tools you only need the shear.
Rothenberger Direct Cut 55089 PEX Shear 1-3/8" Max OD - Amazon.com
12 bucks or so.
