Old 05-15-2010, 07:55 AM   #1
Way to early
First night out in our new trailer and at about 5:00 am I have found the first mod I need to do black out the vent over our bed. Don't get me wrong I don't mind getting up early but I am not going to work so 7 is early enough. Any suggestions besides the obvious of painting it? I do have a max air vent cover.
2002 Dodge 2500 5.9 CTD
2011 2501ss Rockwood Roo
1200 WD Reese hitch
Snivek is offline   Reply With Quote
Old 05-15-2010, 08:21 AM   #2
acadianbob's Avatar
Still going to be a problem when the vent is open isn't it? How about some eye blinds?
2018 F250 Lariat 6.2 4X4 w 4.30s, 2018 Wildcat 29RLX
2003 Yamaha FJR1300, Demco Premiere Slider
Red Green coffee mugs
Old 05-15-2010, 08:28 AM   #3
milzat's Avatar
CAMCO Dual vent cover.
This is one of the first mods I've done.
East to install, easy to remove. Adjustable positions for ventalation if needed.
milzat is offline   Reply With Quote
Old 05-15-2010, 08:55 AM   #4
I like the camco dual vent cover. Gonna have to look around town for one before may long
1200 WD Reese hitch
Old 05-15-2010, 01:14 PM   #5
powerboatr's Avatar
i painted my max air covers with the fusion pain, i found colors that complemented the rv color.
Living in the Piney Woods of Texas.
powerboatr is offline   Reply With Quote
Old 05-15-2010, 03:45 PM   #6
milzat's Avatar
I applied a couple coats of 3M Rubberized Undercoating on the exterior of the factory vent. This stuff is black and blocks out the sunlight. I removed the MaxxAir vent covers, prayed the undercoating, then re-installed the MaxxAir.
Professional Grade Rubberized Undercoating (16 oz.) by 3M - Part 03584 - Advance Auto Parts
Old 05-15-2010, 11:50 PM   #7
You can cut a piece of foam a bit oversized, and it will fit in the opening very nicely from the bottom. If you want to remove it, simply pull it out! Randy
Old 05-16-2010, 06:10 AM   #8
MtnGuy's Avatar
I am kinda the other way around.....I wish mine were completely clear so I can see the tree silhouette or stars at night while laying in bed.
Old 05-18-2010, 07:23 AM   #9
2011 Berkshire 390bh
wnytaxman's Avatar
We just put one of those insulating inserts into the vent and pull it out when we want it out. Fast, simple, and it helps to keep the room comfy.
wnytaxman is offline   Reply With Quote
